Trade: Framing
97' F-250 Grinding 2nd Gear
When I down shift to 2nd gear it will grind until i get to about 3 or 4 MPH then it goes right in. None of the other grears have this problem. Any ideas??
Also, what price would you put on an 97' F-250 power stroke, supercab, manual trans, in good condition. Last edited by 10Heavy; 07-11-2007 at 10:43 PM. |
Licensed Electrician
Trade: Licensed Electrictian
Re: 97' F-250 Grinding 2nd Gear
Sounds like a 2nd gear syncronizer (sp) bad.
Follower of Jesus Christ |
Trade: Framing
Any idea what that would cost to fix
Young Gun
Trade: Smartass
Umm I know how to do a second gear syncro in a t-56 and you can do it farly easy if you would like to do it yourself. You will save tons of money if you bring the tranny to the shop not in the truck. Probably 1000 bucks. They charge a ton of money to take them out and put them in. I would say 1000 dollars max to fix it. How many miles and where are you located at? I need a work truck.
Even without a synchronizer, if you blip the throttle when downshifting, you can eliminate the grinding. If you do that when the synchronizer is working, you eliminate the wear the 'just' downshifting causes.
Frank Slate Roof Repairs, Richmond, Va. |
Trade: Remodeling and Repair
Kind of related to what tinner stated, double-clutch your downshift.
You bleep the throttle, but with the clutch out in neutral. The faster your moving the more throttle you need to give it. You really need to shift it like a truck that has no syncros, like a 10-Speed Road Ranger trans for example. If you decide to change the trans, try to see which ones will interchange in your truck. If there are many to pick from, buying a used one may be cheaper. |
| Top Gear | Nathan | Off Topic (Non Trade) | 9 | 02-05-2007 07:32 PM |
| Removing asbestos floor tile: Space suits needed? | Ted W | General Discussion | 19 | 01-29-2007 02:38 PM |
| Paint on concrete - Grinding or blasting? | Minuteman | Flooring | 7 | 09-15-2006 01:04 PM |
| Grinding concrete | InterlockPavers | Masonry | 11 | 06-26-2006 07:16 AM |
| In Gear Business Management | donb1959 | Business | 2 | 04-09-2006 11:09 PM |
