Joe Maurino
Guest
Posts: n/a
Zero Clearance Curcular Saw
I have come across a problem, that is I am going to need to remove a random plank oak flooring the problem the cabinets were set over the floor.
I need to flush cut the old floor at the base of the cabinets. I have only 4 1/2 inches to work under. Does anyone have any ideas? Thanks Joe |
Rich Turley
Guest
Posts: n/a
Re: Zero Clearance Curcular Saw
It's called a Toe-Kick Saw, made by Craine. They can be rented in some rental shops.
http://www.westerntool.com/product.htm?pid=436976 Rich |
MechanicalDVR
Guest
Posts: n/a
Been there done that. It's dangerous, but I put a small thin blade that I believe was made by Black and Decker in a Makita 4" angle grinder without the guard and ran it almost flush to the kicks. You lose the thickness of the outter nut on the grinder shaft, easily covered by shoe moulding.
Floordude
Guest
Posts: n/a
Re: Zero Clearance Curcular Saw![]() Crain Toe-kick saw. |
Joe Maurino
Guest
Posts: n/a
Thanks: IT will be a life savior.
Again thanks. Joe Maurino |
Joe Maurino
Guest
Posts: n/a
Thanks. This will be a life savior.
Joe Maurino
Guest
Posts: n/a
Thanks Rich this will rid me of trying to make something that may be dangerous.
Joe Maurino
Guest
Posts: n/a
Thank you Rich. This will keep me form making something that could be dangerous.
Again thank you. Joe Maurino |
Joe Maurino
Guest
Posts: n/a
Thanks I was going to try that, but I have seen a couple of guys get hurt doing that. Some of the guys on line have told me about and toe plate saw. That will do the trick.
Again thanks Joe Maurino |
| !!!Plumbers w/ DOD Security Clearance Needed!!!! | pbanavar | Help Wanted or Looking For Work | 5 | 01-12-2008 07:13 PM |
| recessed lighting clearance | skidmark845 | Electrical | 6 | 07-09-2007 12:02 PM |
| !!!Carpenters w/ DOD Security Clearance Needed!!!! | pbanavar | Help Wanted or Looking For Work | 19 | 04-30-2007 12:14 PM |
| Romex to Steam Pipe clearance? | K2 | Electrical | 3 | 02-22-2007 10:01 PM |
| !!!CERTIFED Welders w/ DOD Security Clearance Needed!!!! | pbanavar | Help Wanted or Looking For Work | 0 | 06-21-2006 11:08 AM |
