Worm Drive Over Side Winder - Page 3 - Tools & Equipment - Contractor Talk
Old 04-27-2014, 10:58 AM   #41
asgoodasdead's Avatar
Rewards Points: 2,198
Re: Worm Drive Over Side Winder
Originally Posted by Birch View Post
Don't watch the blade, watch the guide.
my cuts come out way more accurate/straighter when I watch the blade.
asgoodasdead is offline
The Following User Says Thank You to asgoodasdead For This Useful Post:
RobertCDF (04-28-2014)
Old 04-27-2014, 01:10 PM   #42
Designed2Fail's Avatar
Trade: residential construction
Rewards Points: 234
Is their any learning curve with a worm drive saw? Have always used a sidewinder. Thanks
Designed2Fail is offline
Old 04-27-2014, 01:16 PM   #43
it's a saw. it goes round and cuts. just a matter of adjusting to the weight difference and how the 2 saws are balanced differently.
Old 04-27-2014, 01:53 PM   #44
NCMCarpentry's Avatar
Rewards Points: 860
It'll feel stupid heavy at first. I think you "get used" to it more than get stronger to make up for it... The slower blade feels a bit weird going through light lumber i.e 2x4 SPF. I'd say there's a bit of a learning curve but its the same concept as a sidewinder.
Coming from a guy who switched to a worm drive last month
NCMCarpentry is offline
The Following User Says Thank You to NCMCarpentry For This Useful Post:
Designed2Fail (04-27-2014)
Old 04-27-2014, 02:04 PM   #45
aaron_a's Avatar
Trade: Remodeling and fine carpentry
Rewards Points: 2,238
I bought a worm drive last year for the first time. I picked up a well used 8 1/4 skill for 50 bucks at the pawn shop. It has quickly become my go to saw. The line of sight is great for me, and as a short person, having the extra reach for cutting 4x8 sheets is a nice bonus.
aaron_a is offline
Old 04-27-2014, 02:40 PM   #46
hdavis's Avatar
Rewards Points: 3,925
What blade you use makes a difference - some are designed for worm drives and some are designed for sidewinders.
hdavis is offline
Old 04-27-2014, 02:50 PM   #47
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Originally Posted by Paulie View Post
but you'll have at least one arm that's ripped.
yea..ok Paulie..keep telling yourself it's because of the saw..
Tom Struble is offline
Paulie (04-27-2014)
Old 04-27-2014, 02:52 PM   #48
GC/carpenter
Californiadecks's Avatar
Rewards Points: 4,540
I sometimes switch hands so it feels like I'm getting some "strange"
Californiadecks is online now
The Following 6 Users Say Thank You to Californiadecks For This Useful Post:
asevereid (04-28-2014), CanningCustom (04-27-2014), Inner10 (04-27-2014), overanalyze (04-27-2014), Paulie (04-27-2014), Tom Struble (04-27-2014)
Old 04-27-2014, 02:53 PM   #49
#MAGA
EricBrancard's Avatar
Trade: Builder/Renovator
Note to self: purchase worm drive for cover story
EricBrancard is offline
The Following 3 Users Say Thank You to EricBrancard For This Useful Post:
dkillianjr (04-27-2014), Paulie (04-27-2014), Tom Struble (04-27-2014)
Old 04-27-2014, 03:25 PM   #50
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Degenerates. Those of us that are pure of heart know what I meant.
Paulie is offline
The Following 4 Users Say Thank You to Paulie For This Useful Post:
asevereid (04-28-2014), EricBrancard (04-27-2014), hdavis (04-27-2014), Tom Struble (04-27-2014)
Old 04-27-2014, 04:09 PM   #51
Birch's Avatar
Rewards Points: 1,058
I can cut a line as nice as a table saw and only look at the blade once as it enters the sheet, and that's with a scribed line, by tape measure too. After the kerf is started, I move my attention to the guide, and keep a steady strong feed, so I cut much quicker than a TS too.
I always feel like techniques need to be talked about when comparing the two types of saws. I own both kind, but have more time on side-winders. I started appreciating the Worms more when I started gang cutting rafters/ bird-mouths. With wormies, I tend to be a blade watcher, but I keep aware of the guide (and my other senses too), but w/sw's, I religiously use the guide and my body's senses of sight, hearing, and touch, for sheathing cuts.
Wd's can cut better with dull blades than sw's. I have had some old Craftsman saws that the blade was totally hidden by the housing. I use mostly PC-315-1 mod saws. Drop foot w/top handles. Since they discontinued them about twenty years back, I just keep rebuilding them.
I think once you get a few hundred thousand cuts under your belt, it just happens, either type of saw.
One other thing I do is pull the trigger and never let off. It makes the switches last longer. Brush are cheaper and easier to replace too.
Using a Circ saw is more than just a visual experience. Your other senses are your warning lights on your instrument panel. If it looks, sounds, and feels good, all lights are green.
Keep that baby buzzing!
Birch is offline
Old 04-27-2014, 04:50 PM   #52
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I can cut a line as nice as a table saw and only look at the blade once as it enters the sheet, and that's with a scribed line, by tape measure too. After the kerf is started, I move my attention to the guide, and keep a steady strong feed, so I cut much quicker than a TS too. I always feel like techniques need to be talked about when comparing the two types of saws. I own both kind, but have more time on side-winders. I started appreciating the Worms more when I started gang cutting rafters/ bird-mouths. With wormies, I tend to be a blade watcher, but I keep aware of the guide (and my other senses too), but w/sw's, I religiously use the guide and my body's senses of sight, hearing, and touch, for sheathing cuts. Wd's can cut better with dull blades than sw's. I have had some old Craftsman saws that the blade was totally hidden by the housing. I use mostly PC-315-1 mod saws. Drop foot w/top handles. Since they discontinued them about twenty years back, I just keep rebuilding them. I think once you get a few hundred thousand cuts under your belt, it just happens, either type of saw. One other thing I do is pull the trigger and never let off. It makes the switches last longer. Brush are cheaper and easier to replace too. Using a Circ saw is more than just a visual experience. Your other senses are your warning lights on your instrument panel. If it looks, sounds, and feels good, all lights are green. Keep that baby buzzing! ...
I can cut I straighter line without looking at it at all, having a conversation with someone
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
Birch (04-29-2014)
Old 04-27-2014, 04:58 PM   #53
hdavis's Avatar
I do a surprising number of curved cuts, so I have to go with watching the blade on these. For gradual curves, I'll use a regular blade in the circ saw, but for tighter radius curves I'll use a demo blade - it's so thin it will flex pretty easily.
hdavis is offline
Old 04-27-2014, 05:27 PM   #54
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 2,170
Just wanna know one thing - where is DWB?
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 04-27-2014, 05:35 PM   #55
hdavis's Avatar
Hawaii
hdavis is offline
Old 04-27-2014, 05:41 PM   #56
John the Builder
Originally Posted by hdavis View Post
Hawaii
I'm just fine. Ha why you?
Old 04-27-2014, 06:24 PM   #57
Birch's Avatar
Try closing your eyes . . .
Birch is offline
Old 04-27-2014, 06:44 PM   #58
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
wormdrives are a more versatile tools. Either left or right handed. I for one use a wormdrive with both hands. I am right hand dominant and cut with my right hand 90% of the time. if I am cutting rafter cheek cuts ill switch to left hand.
CanningCustom is offline
Old 04-27-2014, 09:38 PM   #59
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Originally Posted by carpenter uk View Post
thats a trim saw
but a worm drive, and that was the question.
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
Old 04-27-2014, 10:25 PM   #60
Resident Pain
winner by technicality!
The Following 2 Users Say Thank You to CanningCustom For This Useful Post:
carpenter uk (04-28-2014), m1911 (04-27-2014)
Kohler side spray loses pressure Chuck Kiser Plumbing 5 12-25-2012 07:31 AM
Drive nails with an excavator. tgeb Excavation & Site Work 10 01-08-2012 10:05 PM
Worm Drive Oil carp.780 Tools & Equipment 5 06-06-2010 09:13 PM
looking for Worm drive case ideas Erikfsn Tools & Equipment 14 05-08-2010 03:09 PM
side by side comparison of countertop materials grandedecor Kitchens & Baths 7 03-06-2009 08:31 PM
