Worm Drive Oil
Old 04-26-2006, 07:24 PM   #1
MacIndustries's Avatar
Trade: Contractor
Worm Drive Oil
Hi guys, I've been watching this site for a while now and never posted a thread or replied because all of my questions were being asked by other members. However, I checked the oil in my wormdrive saw and noticed it's a little low. Can i use an automotive or some type of gear oil to put in it? or do i have to use oil made by the saw's manufaturer...Thanks....Oh!..by the way....my name is Mac...and ....I'm a tool addict....
MacIndustries is offline
Old 04-26-2006, 08:02 PM   #2
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Worm Drive Oil
Use the manufacturers recommended oil just for piece of mind.
maj is offline
Old 04-27-2006, 05:25 PM   #3
OntarioFramer's Avatar
Trade: Rough Carpentry
Re: Worm Drive Oil
I use the oil they recommend and thats SKil heavy-duty worm drive saw lubricant. It comes in a 240ml squeeze tube and you can buy it for 6 bucks at any home depot
OntarioFramer is offline
Old 05-05-2006, 01:28 AM   #4
kapena's Avatar
Trade: General Building Contractor
Rewards Points: 332
Re: Worm Drive Oil
I used automotive gear oil in one of my saws many years ago and it is still going strong.
I figure saw manufacturers make saws, not oil, so they must be just packaging the automotive stuff to make an extra buck. Saw gears won't get anywhere near the pressure and wear as an automotive differential. People who buy bottled water often end up drinking the same stuff the the city supplies out of the faucet. They just pay a lot more for it.
kapena is offline
Old 05-05-2006, 08:38 AM   #5
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
Rewards Points: 1,000
Re: Worm Drive Oil
I use GL5 in mine
A+Carpenter is offline
Old 11-13-2007, 06:30 PM   #6
MellowYellow's Avatar
Trade: carpentry
Re: Worm Drive Oil
Here is a simple test: Put some fresh hypoid gear oil (GL5 rating) in your saw and run it for a few minutes. Then take the filler plug off and see what the condition is. I tried the Milwaukee brand in my Skil 77 once and when the plug came off it looked like shaving cream inside... The oil had foamed up so much it came bublling out of the filler hole! Use whatever but run the test as I said. If you see little or no foam when you pull the plug then you are good to go...
MellowYellow is offline
best/lightest worm drive circular saw? Adenmoor Tools & Equipment 48 01-12-2014 09:04 PM
SanDisk 1GB Flash Drive Leo G Technology 1 01-11-2007 02:35 PM
Worm drive... ruskent Tools & Equipment 38 07-22-2006 09:38 PM
worm drive lukedogg Carpentry 12 06-01-2006 08:36 PM
Jump Drive Question Robie Technology 2 05-09-2006 03:10 PM
