05-21-2009, 07:59 PM
#1
Eckwitte
Trade:
Residential Renovation
White Makita vs Teal Makita
Whats the difference between the new white Makita stuff and the original Teal stuff. I know the white stuff runs on the lower amperage but a buddy of mine told me that they use more plastic parts in the white stuff. Anybody know? If this is true then im guessing its geared for homeowners.
05-21-2009, 08:03 PM
#2
LRG WoodCrafting
Trade:
Professional Sawdust Producer
I've got two of the compacts and they work fine for me. It has the smaller 1.5AH battery and if you aren't carful you can get a pretty good wrist twisting.
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Originally Posted by HusqyPro
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
05-21-2009, 08:18 PM
#3
Trade:
Finish Carpenter,Deck Builder, Contractor
Some one told me that you can use the batteries from the white makitas in the blue makitas but not the blue makitas to the white makitas! or vice versa!
not sure but i have all the blue makitas, including that right angle impact driver!( A MUST HAVE FOR CAB INSTALLERS)
The Bitterness of Poor Quality Remains longer Than The Sweetness Of A Low Price Is Forgotten
#4
Trade:
Remodeling & Decks
I have both. I can't tell a difference other than I grab the white one first because it's lighter.
As far as durability, my teal's have been repaired more than my white's.
05-21-2009, 08:28 PM
#5
LRG WoodCrafting
Trade:
I know I can put the 3AH batter on my compact Makita. Does 2 things. Makes it go longer and makes it heavier.
Carpenter by day.
http://lrgwood.com
05-21-2009, 08:34 PM
#6
Trade:
leo you mean the 3.0 battery on the white makitas works..?
05-21-2009, 08:37 PM
#7
LRG WoodCrafting
Trade:
It should. I have a buddy that has the bigger battery for the Saw. I put the small battery on the saw and it worked. I think I put the 3AH batter on my compact, not positive about my memory. CRS disease.
Carpenter by day.
http://lrgwood.com
05-21-2009, 08:38 PM
#8
Trade:
the only blue makita i had trouble with was the hammer drill. i was going to buy a new one but turns out im 3 miles from a makita service center and the guy there fixed it in 5 min ! Great people there
05-21-2009, 08:43 PM
#9
LRG WoodCrafting
Trade:
Features:
Makita built, 4-pole maximum torque motor delivers 450 in-lbs of efficient torque in a compact size.
More compact design at only 8" long and weighs only 3.5 lbs. for less operator fatigue.
Batteries charge 4X faster in only 15 minutes.
Ergonomic shape fits like a glove with even pressure and easy control.
Makita Lithium-Ion provides longer run time, 5x lower self-discharge (for use any time) &16 firm holding contact terminals (for constant high power).
15-minute Rapid Optimum Charger and battery communicates throughout the charging process using the built-in chip in the battery and built-in CPU chip in the charger. The Charger also uses "Active 3 Control" for current control, thermal control & voltage control.
15-minute Rapid Optimum Charger has a built-in fan to cool the battery to produce more lifetime work.
Built-in LED light illuminates the work area.
Accepts all Lithium-Ion slide-style batteries.
3-year warranty on tool and 1-year warranty on battery.
Carpenter by day.
http://lrgwood.com
05-21-2009, 08:44 PM
#10
Trade:
i know the smaller battery will work in the saw, i,ll be honest im happy with the blue ones! and there really light as it is. if i need compact i go to the angled impact.. i can fit into a 9" cab, predrill the face frame and screw 2.5" screws!
05-21-2009, 08:47 PM
#11
LRG WoodCrafting
Trade:
This is smaller and works great inside of cabinets
Carpenter by day.
http://lrgwood.com
05-21-2009, 08:48 PM
#12
Trade:
Remodeling & Decks
Yeah, that's probably the place I send my stuff to in NJ via UPS. The only issues I have had (multiple) is with the Teal hammerdrill. 3rd gear always dies.
05-21-2009, 09:02 PM
#13
King Nothing
Trade:
Remodeler/Builder
3rd gear died on me too. I took it to a makita dealer and they rebuilt the drill and gave me a new charger because of the noisy fan.
05-21-2009, 09:15 PM
#14
Eckwitte
Trade:
Same thing happened today to my buddy, he has the 3 speed 18v li-on hammer drill and just today it wouldn't get into hammer mode...I know a couple people who have had problems with that model. The makita dealer even told us after rebuilding it twice that they weren't designed properly and that on speed 3 they will always give out. I have the 2 speed lighter duty one and i use it quite a bit no problems...but it takes a hell of a long time to hammer drill a 3/16 hole!
3 Speed : toolmonger.com/2008/02/20/makita-18v-li-ion-hammer-drilldriver-kit/
2 Speed : professional-power-tool-guide.com/2009/01/makita-lxt-drilldriver-review-bhp452/
Reason: just because
05-21-2009, 09:21 PM
#15
Trade:
same here greg, 3rd on hammer drill for me too. had it fixed twice! apperently there is a slip ring washer that gets mangled when you hammer drill in 3rd! when i brought mine in he told me makita does not recommend hammer drilling in 3rd gear!
05-21-2009, 09:25 PM
#16
King Nothing
Trade:
Remodeler/Builder
That's the first I've heard of that. It's simply retarded to say "Don't use the fastest gear for drilling"  . Freakin Makita!
05-21-2009, 09:26 PM
#17
Trade:
i have this one leo, 18 Volt blue
05-21-2009, 09:29 PM
#18
Trade:
i know, did you ever try to go thru tile in 2nd gear. your practically standing still!
05-21-2009, 09:30 PM
#19
LRG WoodCrafting
Trade:
Ya, that would work too.
Carpenter by day.
http://lrgwood.com
05-21-2009, 09:34 PM
#20
Trade:
its awsome for tilt out sink base draws.(even when the tops and sinks are installed) its got the pattended light!...
 THANK YOU MAKITA
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
