Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 10-24-2009, 08:49 AM   #1
Wheelbarrow style electric compressors
I am considering the purchase of a new compressor that will run a couple of nail guns. I used to have an Emglo but as Dewalt has purchased they're line I am not sure how well the are performing in the field. Any advise would be welcomed.
Thanks.
handyworks is offline   Reply With Quote
Old 10-24-2009, 08:53 AM   #2
framerman's Avatar
Trade: Framing, Custom Carpentry, Architectural Design
Jenny Compressors are the industrial Emglo compressors. DeWalt is a cheapened down version IMO.
RolAire is a good one also.
If one advances confidently in the direction of one's dreams,
and endeavors to live the life which one has imagined,
one will meet with a success unexpected in common hours
~Henry David Thoreau
framerman is offline   Reply With Quote
The Following User Says Thank You to framerman For This Useful Post:
handyworks (10-24-2009)
Old 10-24-2009, 09:58 AM   #3
MikeNeufeld's Avatar
Trade: Trim Carpenter
I second the rolaire. YOu could also try out the new Bosch which I believe is made by Fini compressors in Italy. They are supposed be be really good
MikeNeufeld is offline   Reply With Quote
The Following User Says Thank You to MikeNeufeld For This Useful Post:
Old 10-24-2009, 10:10 AM   #4
loneframer's Avatar
Trade: residential framing/general carpentry
Not sure about the DeWalt Emglos, but the older electric Emglos were good for tripping the 15 Amp circuits on the temp poles. Code enforcement would only allow two 15 amp GFCI circuits on a pole. We had better luck with oil-less models, especially in cold weather.
BTW, I just scored a pre DeWalt Emglo with a Honda 5.5 horse gas engine for 100 bucks. It wouldn't build pressure, but ran like a champ. I know it had compression because it was blowing air back through the intake. Pulled the top off of the pump and found a small piece of a valve spring stuck in the intake side of one of the cylinders. YeeeeHaaaa
" It's a Jersey thing, you wouldn't understand"
loneframer is offline   Reply With Quote
Old 10-24-2009, 11:02 AM   #5
JumboJack for president!
XanadooLTD's Avatar
Trade: Hilti walking billboard
i just bought the 8 gallon wheelbarroe bosch. It is sweeeeet. it has a honda engine. Fills in like 14 seconds. The handles act as an aid to load the 175pound compressor into the truck. I think it is the best compressor out at the moment. Ive looked into them all. Check out Boschtools.com
XanadooLTD is offline   Reply With Quote
Old 10-24-2009, 12:28 PM   #6
JFRAME
Trade: carpentry
rol-air,I've got elec and gas powered they are BULLETPROOF
JFRAME is online now   Reply With Quote
The Following User Says Thank You to JFRAME For This Useful Post:
Old 10-24-2009, 03:02 PM   #7
Great find!
Thanks for the input. Lucky you, great pick up. I would have jumped at the chance myself.
Handyworks
Old 10-24-2009, 03:03 PM   #8
Price$$
Were you able to by it for under $1,500?
Thanks,
Handyworks
