What Laser Can Put A Line On The Floor? PLS-5?
I need a laser to do and check layout. I looked at the PLS-5. I want it to check square with a visible line on the floor. I have a Dewalt plumb laser already. Any suggestions?
Off |
Professional Remodeler
Re: What Laser Can Put A Line On The Floor? PLS-5?
I use this for tile and walls, it's only $40 from home depot and does a decent job. You don't say what requirements you have for length of line and brightness though.
This one gives 15-20 foot lines in average lighting, does good enough for setting tile as it shows up in the thinset, you don't have to worry about covering your line. I also use it for laying out square lines for partition walls for offices, basements, etc. If you want continuous lines on the floor and want to go with Pacific Laser, try the PLS90e Link: http://contractorstools.com/pls_90e.html
-Mike- Falcon Contracting Residential - Commercial
Thanks mike
THe PLS90 looks like the ticket |
If I were you Id buy one of those new sattelite lasers, they can shoot a line on almost anything.
P.S. if you buy one make sure it Chinese Missile protected... |
| Shingles Nailed Above Nail Line.. Help!! | Unregistered | Roofing | 24 | 04-20-2011 09:14 PM |
| Gas Line - Can't Find The Leak | jman116 | Plumbing | 27 | 08-19-2007 11:19 AM |
| Straight Horizontal Line | Speer007 | Carpentry | 17 | 12-15-2006 06:26 PM |
| Laser level for top plates on partition walls? | personalt | Framing | 3 | 11-12-2006 09:58 AM |
| Replacing residential sewer line | threequez | Plumbing | 1 | 10-17-2006 05:09 AM |
