Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 10-28-2009, 04:24 PM   #1
DavidC
DavidC's Avatar
Wet grinder
I have an Alpha vsp - 120 wet grinder purchased new this summer. After less than 24 hours working time it quit. First symptoms were that it would stop and start while using it but then wouldn't run. The GFCI tripped whenever I hit the switch.
Took it apart and found one of the brushes had worn at a angle and the commutator was dirty. I reshaped the brush and cleaned the commutator. Reassembled and it worked just fine.
Back to work with it and used it about 1 1/2 hours with out incident. Shut it off, took a break and went back to the same problem. No start and the GFCI trips. Took it apart again, brushes ok this time but the commutator was even dirtier than the first time. Cleaned it and it seems to work fine.
Just wondering if anyone else with this grinder has a similar problem.
Good Luck
OK, rant if you must. For the love of Pete, use paragraphs and spell check.
DavidC is offline   Reply With Quote
Old 10-28-2009, 06:13 PM   #2
concrete designer
Trade:
That sucks! I have a Hellcat ??? something, that I have had for 3 years that worked great up till about 2 months ago... It would randomly not want to start when you flipped the switch. After I did a basic tune up,... banging on it from every angle, it now works but over heats. I have no help for you but have had really worry free use out of mine till recent.
user50444 is offline   Reply With Quote
Old 10-28-2009, 09:29 PM   #3
Trade: Remodel/Deck
Not meaning to hijack, but I've been looking at wet grinders lately. I was looking at the Alpha, but they have had some mixed reviews. I'm looking at the Flex LW 603 VR. I posted the link below. Any thoughts on that one?
http://www.flexnorthamerica.com/lw603vr.html
Rustbucket is offline   Reply With Quote
Old 10-29-2009, 07:07 PM   #4
Trade: General Construction
The stone guys I know use the Makita and they swear by them.
Pw5001c
jiffy is offline   Reply With Quote
Murder: What's the best grinder? Tinstaafl Tools & Equipment 35 10-21-2009 09:19 PM
Bosch 1775E Tuck Point Grinder INTRA Masonry 4 06-30-2009 06:06 PM
Scribing with a Grinder basswood Finish Carpentry 16 04-21-2009 12:04 PM
For all you tool buffs.......grinder ? mckellarman Off Topic (Non Trade) 3 03-27-2009 11:33 AM
Floor Grinder and Sub floor rotarex General Discussion 4 01-17-2009 10:06 PM
