Trade: electrician
Well I Never Thought It Would Happen To Me.
well today i almost broke my wrist and knocked myself out with my own elbow. can anyone guess how?
i was boaring out some holes today with a corded drill in some doors for privacy deadbolts and the hole bit hung up and almost clocked my self a good one and now im out of work for two weeks with a sprained wrist and elongated forearm muscle. can anyone recommend a good corded powerdrill with a CLUTCH for doing stuff like that and also for drilling studs to run romex/wiring and such? i guess we can rule out milwaukee cause i just looked through their 2006-2007 catalog and the one that almost took me out was a milwaukee. TIA CB |
Re: Well I Never Thought It Would Happen To Me.
I know the Bosch has one. Works nice in cases like that.
On a side note, me and the guys on my crew used to have a "teach him a lesson" trick. If they ticked me off, I'd make them go get a drill and drill out the dryer vent hole which was a 4½" hole saw drill attached to a decently powerful drill. I'd say something to the effect of "go do this, you can't harm anything by doing that, now go do that and prove you belong back here" It was my own personal hazing of crew members
Fentoozler
What's wrong with using an 18v + cordless drill for this light work?
Trade: Low Voltage
Did the drill have a chuck handle on it? Were you using it? I find that helps quite a bit when I hit a nail or something.
Trade: Log Home Construction/College Student
We use the Milwaukee Super Hawg to drill a 2" ship auger bit in our logs for electrical. It has a clutch and is long enough to control. This might be a little big for you so you might want to try a spade drill.
![]() Its triple gear reduction so it has lots of torque it spins at 500 rpms. About $169 at Cheapo Depot.
"Listen, you're my family and I love you but you're all terrible at what you do here and I feel like I should tell you, I'd fire all of you if I could." |
ContractorTalk Flunkie
I always use my 18 volt Makita for drilling locksets. and for electrical for that matter.
T.C. "Never met a man yet that I couldn't learn something from"Met a few you couldn't teach though http://remodelingncarolina.com
NJ Plumber with ATTITUDE
Trade: Plumbing Contractor
It's you it isn't the drill. I use a hole hawg daily and other guys call it the suicide drill. If you use the long handles and hold it right it will never hurt you.
Trade: Construction
Even though there are certain ways to hold a drill, SOMETIMES one can forget including this poster. I also recommend the super hawg because it has a clutch for those dangerous situations. For some reason, Milwaukee did not build any of its hole shooter drills with a clutch.
#9 | ||
Trade: electrician
Re: Well I Never Thought It Would Happen To Me.Quote:
i didnt mention it before but i was using the milwaukee 0302-20 corded drill. |
Trade: Finish Carpentry
I think this has happened to use all at one or another,I've found that a finer tooth hole saws work best .They don't catch as sudden but take a little longer to drill . Milwaukee hole saws have finer teeth and is what I use. Always have leverage and be prepared for the sudden stop.
Trade: Residential Remodeler
The larger the cutter the slower the speed should be. I know it's hard to slow down.
Trade: Licensed Electrician
Re: Well I Never Thought It Would Happen To Me. |
Young Gun
Trade: Smartass
get a right angle drill if your running through studs they are extremely nice to work with. I too have never been turned by a drill. Yes I am knocking on wood right now tho!!!
| Warhousing Materials: Your Thought! | mseneker | Drywall | 8 | 12-31-2007 08:10 PM |
| Thought This Was Here In Detroit For A Second | firemike | Off Topic (Non Trade) | 2 | 11-18-2007 02:18 PM |
| Just a thought. . . . | MassMan | General Discussion | 11 | 02-15-2007 09:07 PM |
| ever thought about franshising | rservices | Business | 11 | 10-04-2006 11:17 AM |
| Thought it was hot out, this boils me! | jmic | Off Topic (Non Trade) | 13 | 08-02-2006 07:34 AM |
