bathroom guru
Veritis Set-up Blocks From Lee Valley
Hey everyone,
I just finished reading the posts on Levels ( I own 4 Stabila - they are the best!!). I would like to add that there is another product which is a perfect compliment to the accuracy of Stabila levels. That is a set of "Set-Up Blocks" made by Veritis and sold by Lee Valley (thats in Canada eh!). This set has acurately machined blocks (from aluminum) in 1/16", 1/8", 1/4", 1/2", and 3/4", plus a machined steel block which measures 1"x2"x3". With this set you can measure gaps from 1/16" to just under 4" in 1/16" increments. When you are leveling, you often need to know what the gap is in order to be level. This often means trying to hold the level perfectly while using a tape measure to measure the gap. Not always the most reliable!! With set up blocks you simply use whatever combination you need to center the bubble. Lets say is looks like about a 1/4" so you put the 1/4" block under, oopps, not quite, lets add a 1/16", oh no, not quite!!, take out the 1/16th and add the 1/8", and presto, you are perfectly level and know exactly what the gap is. I use these every day!! |
Re: Veritis Set-up Blocks From Lee Valley
I use shims.
I use the set up blocks to set up my router table and table saw set ups.
| I need help terminating Cat5e phone blocks | Magnettica | Low Voltage | 37 | 02-24-2008 08:51 PM |
| roof valley | Fix-it | Carpentry | 3 | 11-12-2007 07:41 PM |
| Building Blocks for Retaining Wall | robertc65 | Landscaping | 2 | 04-25-2007 03:53 PM |
| CMU Blocks per man under 'ideal' conditions | personalt | Masonry | 15 | 07-28-2006 07:06 PM |
| Valley ends before easetrough - causing failure | mattbradley1 | Roofing | 15 | 05-07-2006 07:49 PM |
