Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 04-30-2008, 05:57 AM   #1
Trade: Home improvements, tile, carpentry,drywall,baths, kitchens
Trailer wiring
Got a used trailer and am trying to get the wiring for the lights to work.
Got a schematic from google- everything works but when I hit the brakes
with the lights on, the brake lights in the trailer go out. Ground???
Any help would be appriciated, thanks.(the harness is a 4 prong hooked up
to a dodge).Also, the trailer dosent have brakes, just running,turn and brake lights.
charlesmd is offline   Reply With Quote
Old 04-30-2008, 06:14 AM   #2
jcalvin's Avatar
Trade for a Chevy.
Cal
You hired WHO
jcalvin is offline   Reply With Quote
Old 04-30-2008, 06:54 AM   #3
Your description isn't clear-do you mean the tail lights go out when the brake lights come on? some vehicles need a converter to 'convert' the vehicle tail lights to operate the trailer lights. Maybe a truck which has separate turn signals and brake lights would be an example-as the trailer uses the same bulb for turn and brake function. is that your problem?
trace the problem down by applying turn and brake function, then independently. Ground could be a problem, but not likely if tail light is working properly. I've had all functions go out before when applying electric brake b/c of a bad ground...not in your case though.
72chevy4x4 is online now   Reply With Quote
Old 04-30-2008, 08:36 AM   #4
mickeyco's Avatar
Trade: Squirrel Handler
Yeah, you're going to have to provide more info, how many bulbs for the tail lights, sometimes the brake and turn indicator share the same filament and that can be a problem and require a component if the vehicle you are hooking up to has separate filaments for brake and turn.
mickeyco is offline   Reply With Quote
Trailer: Customizing ideas needed. Long Robie Vehicles 108 08-27-2009 01:10 PM
Let's discuss the van trailer thing again JPV123 Vehicles 20 12-13-2008 06:42 AM
Buying a Used Trailer Good deal or not? plazaman Vehicles 25 03-03-2008 07:58 PM
trailer security ApgarNJ Vehicles 10 10-18-2007 10:05 PM
mini skid/dingo/skidsteer trailer AintNoFun Contractor Swap 1 12-28-2006 08:46 AM
