Total Station Revisited
Old 02-06-2007, 08:32 PM   #1
Hardibuilt's Avatar
I recently had my first up close experience with a Total Station laying out an irregualar house foundatiion. It was amazing how quick and accurate that the pins went in. I realize that some time was spent by the operator at his home with my plans, but it was quick , quick on the spot.
I didn't use the instrument but watched at a close distance. How easy are these to learn? The gentleman that I used was not the most generous with giving me much knowledge on the subject, but I guess I can't blame him.
In searching I find some units priced in the 2,000 range but most are more like 5-6k. I don't know but it seems that the 2k investment would be worth it knowing the accuracy is nearly perfect.
I have read several earlier postings on this subject, but it seems that most are at least one year old, and I figured with technology more people probably have moved this direction.
Any information on the subject is appreciated.
Hardibuilt is offline
Old 02-07-2007, 10:35 AM   #2
Nac's Avatar
Trade: Concrete, masonry & excavation
Re: Total Station Revisited
I have looked into it mostly to set anchor bolts for colums on larger buildings. A setup will run you about 5,000 for something entry level. I bought a Topcon digital transit with a laser pointer for about 2,000 + which is a big help, but it is only good for setting line and turning angles you still have to tape of distance or cross two points to set your marks.
Nac is offline
Old 02-07-2007, 04:35 PM   #3
Hardibuilt's Avatar
Thanks for the input. I'm going to try and aquire a used unit.
Old 02-07-2007, 05:25 PM   #4
Nac's Avatar
If you buy used make sure it has be recalibrated recently
Nac is offline
total span an total run tlfettled General Discussion 25 06-25-2007 10:01 PM
need pricing for total int. remod sterling stone General Discussion 22 04-06-2007 04:22 PM
Total Station denick Excavation & Site Work 4 06-03-2006 12:23 AM
