#41 | |
Trade: Carpentry / Remodeling
Re: Tools That Changed Your LifeQuote:
those are just too darn expensive for me |
#42 |
Trade: general contracting
Panel Lift
-not just for drywall- used to lift an I beam in place, to lift a portico roof in place before columns were set, used to push/ straighten a girder. It's basically a big jack. Back saver! |
#43 | |
Handle It!
I just find it hilarious that they have created a "NEW" measuring system to make them sound "Tough". Never, never have I heard of "Inch/pounds" of Torque. The REAL measurement is Newton/Meters or Foot/Pounds. Marketing is a wondrous endeavor!
#44 | |
does not make it new. I have a 3/8" torque wrench that's over 35 years old and marked in inch pounds. I've read a lot of specs in inch pounds over the years. Inch pounds have been in use as long as foot pounds.
#45 |
Handle It!
Try Googling Inch/Pound and see how many "specs" use it!
The ONLY thing that utilizes it IS Torque Wrenches!!!!
#46 | |
And .... Just enjoy your ignorance, okay? Be proud.
#47 | |
Handle It!
You are so "The Man". Man! Enjoy your bliss, for they say it is ignorance. You got a problem with me or my post? Tough siht!
#48 |
Mal really needs to go and
educate these poor schlubs. Poor bastards have no idea what they're doing!http://www.tpub.com/content/chinookm...40-23-1_45.htm
#49 |
Ignorance is no sin.
Being proud of it, should be.
#50 |
Handle It!
Find me a conversion site or a wiki entry that supports In/Lb. It is archaic. As useful today as a Dram (An Apothecary Measurement as well as Liquor Apportioning).
All I am saying is that the marketing Gurus use a BIG number to sound BIG. Sort of like Internet speeds...... kBps versus kbps. There is a factor of 8 between the two! Hey! Do not let disagreements of OTHER posts effect your responses. Tis not Healthy!
#51 | |
"There are more things in heaven and earth, Horatio, than are dreamt of in your philosophy."
#52 |
Handle It!
Check yer link....Dink!
Goes nowhere. Just hang it up now.....You are NOT gonna win!
#53 |
Aussie in Norway
Trade: Carpenter and Painter
A converter that changes inch pounds to foot pounds changed my life....
#54 |
http://www.tpub.com/content/chinookm...40-23-1_45.htmhttp://www.tpub.com/content/chinookm...40-23-1_45.htm
Order this information in Print Order this information on CD-ROM Download in PDF Format Click here to make tpub.com your Home Page Page Title: Torque in Inch-Pounds for Nuts Used With Impedance Bolts Back | Up | Next Click here for a printable version Web www.tpub.com Home Information Categories .... Administration Advancement Aerographer Automotive Aviation Combat Construction Diving Draftsman Engineering Electronics Food and Cooking Math Medical Music Nuclear Fundamentals Photography Religion USMC Products Educational CD-ROM's Printed Manuals Downloadable Books Back SELF-RETAINING BOLTS INSTALLATION (Continued) Up TM-55-1520-240-23-1 UH-1H/V and EH-1H Aircraft Manual Next REPLACE LOCKED-IN STUD (AVIM) TM 55-1520-240-23-1 1-14 SELF-RETAINING BOLTS INSTALLATION (Continued) 1-14 c. Place washer(s) on bolt. d. Install nut as follows: If a thin washer is used under the nut, do not let the inner diameter of the washer become caught on the bolt retaining element. False torque readings and damage to the hardware can result. (1) Torque nut to the minimum applicable torque. Check that no axial looseness exists in bolt-nut stackup. CHECK THAT MINIMUM TORQUE OF 10 INCH-POUNDS IS REQUIRED TO ROTATE BOLT-NUT STACKUP. Correct low rotation torque or axial looseness by adding a washer under nut, repeat torquing. (2) Install cotter pin if nut castellations are aligned with pin hole. If castellations are not in line with pin hole, tighten nut as required for alignment. Install cotter pin. Do not exceed maximum allowable torque. NOTE Abrupt increases in torque required to tighten nut is an indication of bottomed thread or jammed washer. Remove nut and examine hardware if such damage is suspected. Torque in Inch-Pounds for Nuts Used With Impedance Bolts NUT MINIMUM TORQUE MAXIMUM TORQUE MS21224-3 15 20 MS21224-4 30 45 MS21224-5 60 90 MS21224-6 85 125 MS21224-7 155 220 MS21224-8 195 280 MS21224-9 280 400 MS17826-4 30 45 MS17826-9 280 400 TORQUE WRENCHES 5 to 50 Inch-Pounds 100 to 750 Inch-Pounds 30 to 150 Inch-Pounds END OF TASK 1-20 Privacy Statement - Press Release - Copyright Information. - Contact Us - Support Integrated Publishing (From maintenance manual for Chinook helicopters)
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 04-29-2008 at 02:07 AM. |
#55 | |
Nothing for me to win. You on the other hand might learn a bit here, if you were not so sure that you already know it all.
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 04-29-2008 at 02:28 AM. |
#56 |
Handle It!
You will soon grow into the shoes you wear.
Face it PAL. Inch/Pounds went out the window BEFORE you or I were born. As a matter.........It was NEVER a real measurement! Again. Show me some REAL tangible websites that explain, support, utilize, convert, or even apply this system to real-World, modern-day applications. You can not do it. Anyhow......................If you back track to my ORIGINAL post, you will see that I ADMIT that I have never heard this term prior to this day. I asked more questions so I may become more "well versed" in this field. So far NO ONE has been able to supply any pertinent info. And you are not adding to the cause. Just being Myopic.
#57 |
Handle It!
Post Script Neo.......
Alcohol and Posting rarely mix well!
#58 |
Handle It!
Cut it out Sam........Newton/Meters is what you know. The PROPER force index!
#59 |
Handle It!
This is almost getting to be fun now!
#60 |
When you sober up you will realize that.
| Premium tools...worth it (warning, long post) | samthedog | General Discussion | 25 | 12-31-2011 06:57 AM |
| Offered stolen tools? | bobcaygeonjon | General Discussion | 76 | 06-02-2008 09:51 PM |
| Is anybody using SHEETROCK Tools? | Big Bison Tools | Drywall | 1 | 11-01-2007 07:47 PM |
| Opinions on the best tools for Pex | Dragonheart | Plumbing | 1 | 07-06-2007 04:16 PM |
| Life insurance/ investment | K2 | Off Topic (Non Trade) | 1 | 09-14-2006 04:16 PM |
