I'm just stirring the:
Trade: .
Thou Shalt Not Laugh - Anyone Own A Model 691 Porter Cable Router
After you stop laughing at the stupidness of my quandry, I need a little long term memory stimulation
![]() I have a model 691 router, that 10 years ago I took the D handle off of and mounteed to my router table. I mostly use it for 'fine woodworking' projects and therefore used the smaller knob grips and the table and had no need whatsoever for the D handle which sat unused for literaly 10+ years! Recently I needed to work on some large pieces of lumber with more hefty bits and I wanted the extra control offered by the D handle. The problem is when I re-attached the D-handle I could not get the router to start using the D handle's switch. There was no problem getting the router to go using the toggle switch on the main housing when I plugged it in directly and I completed the project using the D-handle for leverage only, but when plugging the housing into the d handle, power is not making it past the D handle making turning the router off a 2 handed operation. Not a crisis but mildly annoying... There are 4 screws that are in use on or near the handle here. a large one that attaches through and underneath the router to the handle. One that comes in from the outside top of the handle, and then 2 small screws with lock washers which are on raised posts UNDER the handle. I attached the 2 wires coming from the handle to these two posts with these little screws. When the router did not start I suspected a polarity problem and switched the wires to the opposite posts. STILL no joy. I wonder what I did wrong. So.... What am I forgetting about how to re-attach the handle in order to get power? Maybe the wires are both supposed to go to ONE post? I don't want to try that unless I am pretty certain I wont be causing a short. I cant imagine 10 years of non use would cause a failure in the switch and handle components... I have to have forgotten something. I looked at the manual that came with the router but there was no help there. Removing the handle was not covered much less re-attachment. I looked at the updated PDF manual online. Again there was no instructions on correctly removing the router handle and replacing it. So do any of you have familiarity with this tool? What did I forget in my addled brain. I know it worked when it was new.... I used it with the D handle one time on a small project and decided at that point for work on hardwoords and little stuff I wouldnt be needing the D handle and would use the table mostly. Thanks guys, Charles
Memorable Places - My little home on the web Member of the White Knights Of Contractor Talk Last edited by CGofMP; 04-16-2005 at 11:27 PM. |
Re: Thou Shalt Not Laugh - Anyone Own A Model 691 Porter Cable Router
Not familiar with that particular router, - - maybe the D-handle switch has a safety? The switch shouldn't really have any polarity. Try 'securing' the router and 'shorting' the two wires together, - - if it starts up it's your switch, - - if not it's the wires.
Even if there are no instructions on removing the D-handle, - - how about a blow-up of all the router parts/locations, - - that should help somewhat.
Finish carpentry contrctr
Trade: Finish carpentry contractor
Charles,
I love the D-handle PC router. In fact after years of the bits wearin' on the cord |
#5 | |||
Trade: .
Re: Thou Shalt Not Laugh - Anyone Own A Model 691 Porter Cable RouterQuote:
:Thumbs: I TRULY appreciate the offer to have you pull the D handle and letting me know. Thanks so much. By the way, yes, as you say, this is an excellent router.
Memorable Places - My little home on the web Member of the White Knights Of Contractor Talk |
#6 | |
Trade: .
Closure... maybe...
I wrote PC online... usually have a bad time with responses from companies, but both PC and Milwalkee seem to respond within 48 hours.. not bad. I'd also asked them about the availability of an extra base to keep mounted to my table... Here is what they said: Quote:
Thanks for all the help guys. Charles
Memorable Places - My little home on the web Member of the White Knights Of Contractor Talk Last edited by CGofMP; 04-19-2005 at 08:44 PM. |
| porter cable palm belt sander | Bone Saw | Tools & Equipment | 5 | 04-18-2007 06:47 PM |
| porter cable drywall sander | tgates | Contractor Swap | 5 | 01-24-2007 09:51 AM |
| Kreg Jig K2 vs. Porter Cable 550 | OlTrimguy | Finish Carpentry | 8 | 09-18-2006 08:22 PM |
| Porter Cable Framing Nailers | Reno | Tools & Equipment | 10 | 05-04-2006 11:44 AM |
| GREAT Custome Service from Porter Cable | JPV123 | General Discussion | 3 | 04-06-2006 09:06 PM |
