Finish Carpenter
Trade: Finish carpentry
Table Saw Problem
I have a portable rigid table saw that you've probably seen on at Home Depot. Well the fence isn't that great, although I can get it square by pulling back on the fence before locking down. I have a problem of no matter what I do, the wood always drifts off the fence through the cut. The fence is square to the blade. I wish I could make it stick to the fence somehow? Thanks for any info
Dano |
Feedin the geese
Trade: Finish Carpenter
Re: Table Saw Problem
Well this sounds like a technique problem, may I suggest using a feather board?
JumboJack for president!
Trade: Hilti walking billboard
agreed technique. Unless the blade is crooked causing the wood to shoot out not straight
Trade: carpenter/ handyman
or possibly a dull blade?
Steve |
Insert title
Trade: Doors-Windows-Decks
If you are talking about the one that includes a stand I have the same one. Look at the fence where you lock it down, you can move a couple of screws to square it up. I had the same drifting issue until I spent the time making mine perfectly square.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
Finish Carpenter
Yes, it is the one with the stand. I will mess with the fence tomorrow. I am also going to make some feather boards
Thanks for the info.
Insert title
If you come up with a clever way of attaching a feathering board to your saw's square post a picture.
I like Green things
I bet the real problem is that it is orange. The only portable table saw to own is the bosch with the gravity rise stand.
Trade: Log Home Construction/College Student
The only portable saw on the market is the Dewalt 744X with the rack and pinion fence. Gravity rise is nice, but I'd rather have a fence that is always square with the blade.
"Listen, you're my family and I love you but you're all terrible at what you do here and I feel like I should tell you, I'd fire all of you if I could." |
I like Green things
Never had nor seen a problem with the Bosch's. But most people I know including myself treat their tools better than their children. Yellow is for boat anchors.
Motorboatin' son of a ...
Sounds like the fence isn't tight enough. There is an adjustment nut at the back of the fence. See page 38 of the owners manual. That will tighten it up so that it won't move once it's set. It's either that or you're not keeping the work against the fence. Use a feather board if you have to. Page 23 of the owner's manual.
http://www.ridgid.com/ASSETS/DBFC5B5...LS_213_eng.pdf Last edited by BKFranks; 05-22-2008 at 08:25 PM. |
Trade: carpenter
Try the dewalt flip over bit heavy and restricted on the mitre, but a good all round site saw.
If the fence is secure, - - and it's parallel to the blade, - - the problem you're having is 'flex' in the (arbor) shaft.
As you're pushing the wood, and putting pressure on the shaft, it's flexing away from you and going out of parallel from the fence. You need a better table saw. Last edited by Tom R; 05-22-2008 at 08:43 PM. |
I like Green things
Re: Table Saw Problem |
Trade: carpenter
HI Bukemdando some times these table have a habit of twisting when you push the stock through the ,saw just ease back and see if the table moves then you know the legs are loose or just allow for it.
| Another 3 phase problem.... | gordfraser | Electrical | 13 | 11-10-2006 08:03 PM |
| Problem with a fan light | wackman | Electrical | 3 | 10-23-2006 04:13 PM |
| Problem with sub with no contract signed | kevjob | Business | 37 | 10-04-2006 11:36 PM |
| Bulging Screwheads not ScrewPops...4 year problem | georgiamudman | Drywall | 9 | 02-03-2006 08:55 PM |
| Washing Machine/Floor Vibration Problem | NHCharger | General Discussion | 13 | 01-18-2006 07:52 PM |
