Table Saw Blade For Ridgid Foam?
Old 05-04-2013, 07:33 PM   #1
duburban's Avatar
Trade: building
Rewards Points: 1,294
I'll be doing the underside of a floor system with ridgid foam. Is there a different blade I should be trying? I'll try something cheap with a really low tooth count. I was wondering if maybe a 4 tooth hardi styled blade would be better?
duburban is offline
Old 05-04-2013, 07:43 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,780
Re: Table Saw Blade For Ridgid Foam?
Combination blade I had in the saw worked just fine for me.
griz is online now
Old 05-04-2013, 07:45 PM   #3
Sisyphus's Avatar
Trade: Renovation and property management
Rewards Points: 875
I cut a bunch of sheets of SM with just the regular blade in my Bosch 4000 table saw and it seemed to cut fine. The sheets tended to take off scary fast when cutting solo so I would suggest feather boards or something equivalent.
I did wonder about where the dust was going and what it might do to the saw. So I ran the vac while cutting and vacuumed the motor periodically as well.
Sisyphus is online now
Old 05-04-2013, 07:59 PM   #4
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
I just did about 15 sheets of 1 1/2". I just used the 50 tooth combo blade I had in the saw. Any blade will work. Your over thinking it.
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
The Following 7 Users Say Thank You to TBFGhost For This Useful Post:
Dirtywhiteboy (05-04-2013), griz (05-04-2013), pinwheel (05-04-2013), PrecisionFloors (05-07-2013), Rich D. (05-05-2013), tenon0774 (05-05-2013), Warren (05-04-2013)
Old 05-04-2013, 08:10 PM   #5
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 707
I have used a seven inch diamond blade in a circular saw it works great and no annoying static charged foam sticking every where.
I guess it would work on a table saw if the hole would fit on the arbor
nicko
"Quality work for those who know the difference"
nickko is offline
Old 05-04-2013, 08:23 PM   #6
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I just use what ever is in the saw at time.
jlsconstruction is offline
Old 05-04-2013, 08:29 PM   #7
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,481
We usually put 2" foam in our partitions when we frame. I take the full sheets home and run them through the table saw with whatever blade is on it. They do tend to flutter around a bit, but never had one kick out.
Easy Gibson
Warren is offline
Old 05-04-2013, 09:06 PM   #8
duburban's Avatar
Trade: building
i've cut a ton of this on a table saw with whatever blade already. just looking for a better way.
i was curious if a lower tooth count would make less sticky gum that catches and pulls the sheet.
duburban is offline
Old 05-04-2013, 09:11 PM   #9
stacker of sticks
Rewards Points: 590
Make one of the wire cutter tools.
Its electric, 8' wire in a jig that goes up and down. It just melts through it.
A mason Around here has one.
Old 05-04-2013, 09:12 PM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,494
There is, a hotwire cutter.
Inner10 is offline
Old 05-04-2013, 09:13 PM   #11
duburban's Avatar
Trade: building
i had such a bad experience with a SIP hot knife i'm not into melting foam anymore! i was down low in a corner and took in so much smoke i could feel the cancer landing.
duburban is offline
Old 05-04-2013, 09:27 PM   #12
stacker of sticks
Rewards Points: 590
YeaH that thing
Old 05-04-2013, 09:31 PM   #13
duburban's Avatar
Trade: building
so what happens with the diamond blade?
i'd like to set something up that my teenage brother could do alone while i'm down in the hole. shooting board, diamond blade or regular blade in a circ saw sounds safe enough...
duburban is offline
Old 05-04-2013, 09:44 PM   #14
Box Builder
Morning Wood's Avatar
Rewards Points: 8,956
Just rip it with a combo blade. The trick is a steady feed rate. If you go too slow it melts and will get gummy and or grab. Run a vacuum too.
Morning Wood is offline
Old 05-04-2013, 09:54 PM   #15
Talking Head
EthanB's Avatar
Rewards Points: 78
Maybe you could buy a blade from one of those deli slicers and modify the arbor?
Or you could just shove it through whatever you've got.
I made a table mounted hot wire cutter for ripping thousands of feet of 4" foam at various angles. It sucked. You have to wear a respirator and who really wants to move their hand towards a scorching hot electrified wire?
Planer.....
EthanB is offline
Old 05-04-2013, 09:54 PM   #16
duburban's Avatar
Trade: building
you guys know this stuff comes pre kerfed for snapping? i just remembered that. a friend of mine was using it to cnc a model and there were these streaks through it that were put in for snapping. it was owens coring pink.
duburban is offline
Old 05-04-2013, 10:00 PM   #17
Fire up the BBQ
griz's Avatar
Originally Posted by EthanB View Post
....and who really wants to move their hand towards a scorching hot electrified wire?...
Who in their right mind would move their hand, to within fractions of an inch, of a sharp. multi toothed blade spinning at 3-4000 RPM?..
griz is online now
darthdude (05-04-2013)
Old 05-04-2013, 10:12 PM   #18
duburban's Avatar
Trade: building
http://www.amazon.com/Festool-493656.../dp/B0033LBOJY
cuts up to 5" of material, i bet theres hardly any dust too.
duburban is offline
Old 05-04-2013, 10:14 PM   #19
Talking Head
EthanB's Avatar
Rewards Points: 78
My friend Stubby does it all the time....
I know what you're saying but the hot wire cutter extends a lot higher and was a lot harder to work around than a blade that extends 1/4-1/2" above the material.
Planer.....
EthanB is offline
Old 05-04-2013, 10:14 PM   #20
Fire up the BBQ
griz's Avatar
Who would want to cut several hundred feet of foam with a sabre saw...
griz is online now
Computerized saw blade sharpening.... PrestigeR&D Tools & Equipment 9 09-06-2012 04:56 PM
Will the foamzall blade fit in any sawzall?? rjf1231 Tools & Equipment 0 08-26-2012 07:57 AM
the shark blade?? ConcreteCutter2 Tools & Equipment 5 11-03-2010 07:19 PM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 01:39 PM
Very small/thin table saw blade Woodcrafter74 Tools & Equipment 25 12-28-2005 06:25 AM
