ContractorTalk Flunkie
Storing Levels On Truck
Over the past 2-3 months I've bought 5 different Stabila levels. As you all know the don't come too cheap. 3 of them are too long to go in the cab or tool box. I'm looking for a good way of storing them (the longer ones) on the truck. I have a PVC pipe (3") mounted to my ladder rack made for one of them but I need a way of locking them. Also I have an extendable one 6' - 10', I think, that won't fit in a 3" pipe. Anyone have a proven way of doing this.
T.C. "Never met a man yet that I couldn't learn something from"Met a few you couldn't teach though http://remodelingncarolina.com
Trade: Custom deck builder
Re: Storing Levels On Truck
I used to have that problem with my Plumb-it extendable level. I was thinking about those weathergaurd boxes I have seen mostly on top of vans around here. They are narrow maybe 12" Wide? I think they are for copper pipe. But they usually have a lock shackle. But then I just bought a trailer and it hangs nicely from the ceiling.
#3 | |
Trade: Kitchen & Bath dealer/remodeler
Re: Storing Levels On TruckQuote:
There are also 4 and 6 " lockable conduit cap kits for sch 40 pvc. Heavy duty plastic or metal. You could also have a local welding shop make something similar to this , made to your specs. Heavy Duty Aluminum Pipe & Conduit Carrier
"We are continually faced with great opportunities which are brilliantly disguised as unsolvable problems." Margaret Mead Last edited by DesPro; 11-23-2006 at 10:48 AM. Reason: more info added |
Back from the dead...
Trade: Paperhanger/Painter
The longest level I use is only 4'. But I keep them locked up in a gun case.
Kinda like this one:
Robert, I wish I could afford a trailer, but truthfully I can't. Not Yet.
Des, I like the conduit carrier, but the PVC lock kit is more to my budget. ProWallGuy, I have a gun case myself, not a fancy one like you pictured, but it is heavy duty and just sitting in my tool shed, maybe I'll break it out and bolt it to my tool box for my 4' and 32" levels. Thanks
Heavy Weight Champ
Trade: finish carpentry
you must really like your level.
Real nice guys |
Who doesn't?
My case isn't near that fancy, but it does lock, keeps them dry, and protects them from bouncing around in the back of the truck. |
Another reason for having a van. Mine mount over the racks/tool boxes in otherwise unused space.
#9 | |
If I were an electician, plumber etc, a van would probaly be my choice.
Trade: site work
how do you glue the caps onto the pipe will Regular pvc cement work or do you need somthing different
Yup regular PVC cement works good.
Dave |
Trade: Finish Carpentry
One day while my buddy and I were sitting at red light on a four lane divided road the cars to our left [two left turn lanes ] had the green arrow then goes yellow and this little honda stops and wham ,a van rear ends him and this wooden four foot level goes flying across the intersection. Took us a few seconds to figure out this guy had put this level in a 4'' pvc on the ladder rack and on impact the cap on the front of the pvc didn't slow it down one bit. Be careful were you put things in your truck/van . I personally have had an accident with a van loaded to the gills with tools and not one was close to were it put in . I thank god I had a bulkhead .
#13 | |
Al Smith
best to use a brass cleanout plug on those pvc carry all tubes. Stabila makes 3 plate levels with extendable ends Stabila type 106T |
Have you thought about building a floor storage unit?
Years ago when I had a extended length 1 ton Chevy van for a work vehicle I built a floor storage system for the van. It was basically a raised floor of about 5" with a 1 1/8" plywood top that was the floor. I cut down some 2x6's to 5" to use as supports and were the dividers for the drawers. There were 3 drawers that would pull out the side door that were used for small parts. And 1 drawer in the back center with 2 doors one each side to store long items. You could do something like this in a pickup and have 1 or 2 drawers and a door to store the levels if you split the unit in 3. And if you put a lock on the tailgate nobody could pull the drawers out or open the door. Also if someone looked in the bed they probably wouldn't even know they were there. Just had a thought about this after I posted: Maybe to keep it dry inside, you could use some Ice and Water shield and wrap the top from side to side over lapping down the sides to a little underneath, or wrap the whole thing all around. And use 2 sheets of 1/2" or 5/8" plywood with the Ice and Water shield in between the sheets on the top. Last edited by Kgmz; 01-20-2008 at 12:46 AM. |
| The Most Beautiful Truck I'd Never Want to Own | elvinstheman | Vehicles | 61 | 10-04-2010 04:46 PM |
| T-bone a Mail Truck - what to do | magnets | Off Topic (Non Trade) | 8 | 10-15-2007 12:12 AM |
| Painted My Truck With a Roller | ModernStyle | Painting & Finish Work | 44 | 07-21-2007 10:11 PM |
| Got another truck | IHI | Vehicles | 14 | 11-12-2006 08:07 PM |
| Finally used my POS dump truck today | IHI | Vehicles | 7 | 03-30-2006 12:37 AM |
