Steel Blade In Miter Saw
Old 01-20-2008, 08:01 AM   #1
shaper's Avatar
Trade: residential construction
I have a 12" Dewalt compound miter saw. My question is, can I put a 12" steel cut off blade in place of the wood finish blade? . I believe the arbor is 1" on both
Thanks
Jeff
shaper is offline
Old 01-20-2008, 08:33 AM   #2
ContractorTalk Flunkie
dayspring's Avatar
Re: Steel Blade In Miter Saw
Seems like I tried that once, I think the blade thickness kept it from working, it's been a while.
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 01-20-2008, 11:21 AM   #3
Moderator
Double-A's Avatar
Read the manual. Asking someone if you can do something the manufacturer is responsible for determining is like asking your girlfriend not to get pregnant after the fact.
New York Times, July 20, 2006
Double-A is offline
Old 01-20-2008, 11:24 AM   #4
BigMikeB's Avatar
Trade: HVAC
You can do it but you need to get a blade that matches the speed of your saw. If the blade spins too fast it will just blow to pieces when you start it. If you are thinking of using a composite blade.
BigMikeB is offline
Old 01-20-2008, 11:31 AM   #5
Dustball's Avatar
The problem with using a miter saw as a cut-off saw are all the plastic parts. You'll melt the guard and whatever else the sparks will come in contact with.
Dustball is offline
Old 01-20-2008, 12:04 PM   #6
BigMikeB's Avatar
Trade: HVAC
I use a 10" Ryobi for cutting threaded rod almost daily and it has been fine for months, maybe if you were cutting softer metals that throw more sparks it would be more of a problem.
BigMikeB is offline
Old 01-20-2008, 02:34 PM   #7
Al Smith
A W Smith's Avatar
what are you cutting Jeff?
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-20-2008, 02:44 PM   #8
shaper's Avatar
Just looking to cut small stock, 1/4" or less
shaper is offline
Old 01-20-2008, 02:57 PM   #9
Al Smith
A W Smith's Avatar
The bigger diameter the blade the faster the edge speed will be. Check the manufactured speed of the saw you will be using and then check the maximum speed of the abrasive blade you will be using. I used a Makita chop saw to cut 2 x 1 1/4 .125 wall stock to make my ladder rack years ago that I MIG welded. I have cut up to 2 x 4 .25 wall steel on it in the past. I had taken the plastic guard off it long ago.
Al Smith
Old 01-20-2008, 02:59 PM   #10
leakygoose's Avatar
Trade: Finish Carpentry
Use a 5'' disc grinder with a 1/16 blade ,works like a charm and wear safety glasses . Miter saws are not cut off saws,they spin way too fast,danger Will Robinson.
leakygoose is offline
Old 01-20-2008, 06:30 PM   #11
General Contractor
nadonailer's Avatar
Yep - I walked on my jobsite one day to find my saw on fire and the guys dumping a bucket of water on it....
"History does not long entrust the care of freedom to the weak or the timid”.
Dwight D. Eisenhower
nadonailer is offline
Old 01-20-2008, 07:57 PM   #12
Dustball's Avatar
Cutting threaded rod isn't too bad- they're quick cuts. The problem appears when you're cutting solid stock and tubing. I use a 4.5" and 7" hand grinder for the smaller stuff, horizontal bandsaw for the larger stuff and plasma cutter for sheet and plate.
Whatever you're using, always wear a face shield! When a blade shatters, it's nasty. I use a Uvex Bionic shield- pretty comfy and hugs your face/neck pretty well for protection from the sparks.
Dustball is offline
Old 01-20-2008, 08:05 PM   #13
The Grand Wazoo
KillerToiletSpider's Avatar
You can pick up a cheap chopsaw for $50, and the abrasive blades are designed to work at the saws RPM.
KillerToiletSpider is offline
Old 01-20-2008, 10:04 PM   #14
There you go!
The right tool for the job...
works first time, everytime.
neolitic is offline
Best Miter Saw Blade 4319hendrie Carpentry 51 12-15-2009 10:32 PM
Blade Wobble New Miter Saw balanceact Finish Carpentry 7 06-03-2008 09:12 AM
glass coated steel haskl33 Excavation & Site Work 3 10-23-2007 11:33 AM
So what diamond blade DO you use? lukachuki Masonry 15 01-03-2007 01:24 PM
Hitachi C12LSH 12" Sliding Miter Saw Leo G Tools & Equipment 7 07-20-2006 01:21 AM
