Stationary Joiner Recommendation
Okay, the 4" benchtop joiner is dead, time for a real one. I definitely want one with it's own stand (not benchtop) and probably a 6" width. I'd like to keep the cost under $500.
Any recommendations? Thanks! |
Re: Stationary Joiner Recommendation
I have a Delta 6" jointer that rarely sees any use. It is okay for 4'-5' stock, but the beds are just too short to efficiently joint a board much longer.
I have started using either my router table with the oufeed table adjusted out or just a handheld router with a straightedge. I find either way much more efficient with less waste than the jointer. Trying to handle a 10' board on a 6" jointer and get a clean, glue-line edge can be frustrating. You will spend a lot less money and get better results, unless you opt for something bigger for a jointer. Just my opinion.
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
Trade: --------
The grizzly 6 inch is available with a longer bed then most. I have heard if you spring for the spiral head, you will wonder how you ever lived without it.
unlicensed hack
Trade: wood butcher
Grizzly.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. |
Master Craftsman
Trade: Rustic interior woodwork
Ditto on the Grizzly.
Do one thing at a time, do it well, then move on. http://www.bigdaveswoodworks.com |
Trade: carpenter
I got a used old craftsman 6" for $100 on Craigslist that works well for me. It's really solid, not like new craftsman stuff. It's on a wooden stand and has a separately mounted motor with V-belt.
Thanks for the recommendations. There was a good article on jointing and spiral cutters in last issue of Woodcraft.
| Recommendation on Single pole double throw (SPDT) thermostats | mtplus | HVAC | 19 | 04-10-2011 10:36 AM |
| Small trim saw recommendation | 72chevy4x4 | Carpentry | 8 | 02-11-2007 09:52 AM |
| Biscuit Joiner | Jeremy E | Tools & Equipment | 2 | 08-10-2006 02:42 PM |
| Tools recommendation | Mr Claude | Tools & Equipment | 25 | 07-26-2006 01:04 AM |
| Furnace recommendation | skippy | HVAC | 8 | 11-10-2005 05:45 PM |
