Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 02-01-2009, 02:17 PM   #1
Stanley Fatmax Lasers
What is the Difference between Stanley Fatmax Laser 77-153 CL2 & Stanley Laser 77-214 CLL?
Buca1025 is offline   Reply With Quote
Old 02-01-2009, 02:35 PM   #2
Electron Flow Manipulator
480sparky's Avatar
Trade: Electrons for cash
The pole?
Age is just a number but mine is unlisted.
480sparky is offline   Reply With Quote
Old 02-01-2009, 02:42 PM   #3
General Contractor
Winchester's Avatar
Trade: Residential & Commercial
I actually don't know, but from my experience with Stanley, I would say the difference is this:
The Stanley Fatmax is more expensive because it says "Fatmax" in the name, and is either bulkier or has some shiny metal parts here and there (or both).
Winchester is online now   Reply With Quote
Old 02-01-2009, 02:47 PM   #4
Sean
SLSTech's Avatar
About 3/32 in 30' & a pole
From the Manufacturer
The Stanley CL2 FatMax Cross Line Level features laser chalk lines that can be projected Horizontally and Vertically at the touch of a button. The magnetically dampened compensator ensures accuracy and reduces errors in a variety of applications. Out of Leveling range sensor triggers the beams to automatically shut off when the unit is moved out of its +/- 4-degree self-leveling range. Use it when ever you need to level or plumb an object. With a leveling accuracy of 5/32-inch at 30-feet and a line accuracy of 3/32-inch at 10-feet, the CL2 is a perfect replacement to your carpenter's level.
Product Description
Stanley, Fatmax Cross Line Self Leveling Laser, Magnetically Dampened Mini Cross Level Projects Bright Level & Or Plumb Lines For Instant Reference Marks At The Press Of A Button, Out Of Level Range Sensor, For Interior Use With A Working Range Of 30', Accuracy 5/32", Can Be Used On A Tripod, Ideal For All Interior Construction, Remodeling & Decorating Uses, Has Many Interior Industrial Applications, Includes Carrying Case.
The Stanley 77-214 CLL Cross Line Laser Kit projects both vertical and horizontal lines at the press of a button. Packaged with a 9-ft laser pole ensures fast and accurate leveling and aligning from the floor to the ceiling. The self leveling feature ensures that the laser is projecting level and plumb lines. Should the unit go out of position, the laser will alert the user by blinking. Great for a wide variety of jobs including, Cabinet installation, shelving, Drop Ceilings, Wall Hangings, Closet Installation, Finish Carpentry, Interior Design and many more. The CLL is accurate to 1/4" @ 30ft and has a working range of up to 32ft. Includes one year warranty. Package includes: CLL, Laser Pole, Quick Release Mount, Batteries and Case.
Product Description
The Cross-Line laser level rapidly and accurately projects both vertical and horizontal lines at the press of a button. The self-leveling feature ensures that the lines are level and alerts the user if the line becomes out-of-level. Heavy duty magnetic damping compensator for rapid and stable leveling. Pendulum self leveling mechanism for accuracy and peace of mind. Heavy duty magnetic damping compensator for rapid and stable leveling. Out-of-level sensor automatically alerts the user that the tool is outside it's +/- 4 degrees self-leveling range and is no longer level. Two 650 nm diodes for maximum line visibility. One-button function- easily switch between four (4) functions: horizontal line, vertical, cross-line and tilt function. Fitted with 1/4-in x 20 thread camera tripod mounting thread. Heavy duty rubber sleeve for added protection and comfort grip. Includes: Laser level, carrying case, batteries, instruction manual.
SLSTech is online now   Reply With Quote
Old 02-01-2009, 02:48 PM   #5
tcleve4911's Avatar
Trade: Remodeling contractor
I looked up the stanley site & the only difference I found was the CLL came with a pole where the CL2 has a separate attachment that has a magnetic hold, a screw hold & a tripod attachment.
I have the CL2 ...Love it.
It attaches to my builders tripod with the 5/8" nut as well as the 1/4" nut that is on most camera tripods.
Quick, easy, accurate & affordable.
Remodeler in Maine & Vermont
Finish carpenter
Been doin' this stuff for a long time.................
tcleve4911 is offline   Reply With Quote
Old 02-01-2009, 10:05 PM   #6
tomstruble's Avatar
Trade: siding
http://www.deckmagazine.com/filereader/1.html theres a good article on lasers here
tomstruble is offline   Reply With Quote
Lasers BKA Flooring 29 07-27-2008 11:29 PM
Setting up pipe lasers ando Excavation & Site Work 6 03-27-2008 05:37 PM
stanley excavator mounted vibratory plate dayexco Contractor Swap 0 10-09-2006 08:19 PM
Pipe lasers Gmads Excavation & Site Work 2 08-09-2006 07:21 PM
Does anyone care about the Stanley Cup? ron schenker Off Topic (Non Trade) 10 06-07-2006 06:24 PM
