Stair Stringer Router Jig
Hello all, I am looking for a jig for routing stairs.anyone know of a place to buy 1 in USA?
Thanks |
Head sawdust creator
Trade: Jack of All.... Master of a Couple
Re: Stair Stringer Router Jig
You can easily make your own outta a piece of ¼" plywood and some strips of ½" x ½" solid stock. Just measure the base of your router and figure out where the outside of your cuts will be using a straight cutting bit.... attach your stops to the plywood and then cut through the plywood and confirm that your treads fit perfectly. Attach to your stringer with screws and cut through your template and into the stringer.... moving template wherever required.
"Whether you think you can or think you can't.... you are right!!!" Henry Ford
| Stair Jig | RISENRUN | Tools & Equipment | 7 | 02-08-2010 08:30 PM |
| Stair Designer | hatchet | Carpentry | 10 | 01-18-2009 08:14 AM |
| Mortising doors, hinges - router template? | MHMConstruction | Finish Carpentry | 11 | 06-07-2007 11:16 AM |
| how to lift headroom at stair base? | karma_carpentry | Framing | 10 | 12-01-2006 08:56 PM |
| OSB hangerboard for stair stringer? | Spencer | Carpentry | 26 | 04-05-2006 07:58 AM |
