Spray Foam Gun
Old 11-14-2010, 08:27 PM   #1
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Spray Foam Gun
Do you use them or just buy the disposable cans for each time you need it?
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 11-14-2010, 08:43 PM   #2
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Rewards Points: 2,022
Re: Spray Foam Gun
Gun
Being able to toss it in my backseat on a Friday and reuse it again on a Monday with only a few seconds of cleaning the dried foam from the head is priceless. Buying foam by the case or at least in the big cans will save you $$$-$$$$ a year compared to buying the not really Great Stuff.
Buy a gun with a smooth head at the end where the foam comes out, the ones with the rims that fit the POS plastic tips suck in my opinion.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 11-14-2010, 09:51 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
Re: Spray Foam Gun
this is the one i use,just need to keep a can of foam on it all the time,you need to spend about a hundred bucks for a good gun,you don't have to constently clean these things
http://www.energyfederation.org/cons...th/21_1177_439
Tom Struble is offline
Old 11-15-2010, 09:27 AM   #4
tcleve4911's Avatar
Re: Spray Foam Gun
Maybe that's the problem.
I'm using the gun that I posted...costs= $40.00
At the end of each use, I take off the foam cartridge and run almost a whole can of the cleaner through it.
I go to use it the next time and it's clogged & won't work.
I've even left the cans on and I run into the same problem
So now I own 3 guns that don't work.
So.....questions
What do you use to clean the foam once it has dried INSIDE the gun?
Does a more expensive gun work differently ...in what way?
Thanks in advance......
Back in Maine
Dubbin' Around
Old 11-15-2010, 11:52 AM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,616
Re: Spray Foam Gun
So.....questions
Nothing you're screwed throw it out.
From what I understand with regular use you almost never have to clean it; just keep a can of foam on it. I've left mine for almost 2 months with a half full can and it still worked perfectly. If your can is spent and you don't have another or your gun isn't working properly then blast half a can of cleaner through it.
Inner10 is online now
Old 11-15-2010, 12:00 PM   #6
tcleve4911's Avatar
Re: Spray Foam Gun
Really?
There's gotta be some outrageous chemical that'll dissolve closed cell foam.....
I'll wait for a second opinion ...but thanks for the advice
Back in Maine
Dubbin' Around
Old 11-15-2010, 05:44 PM   #7
Trade: siding
Rewards Points: 4
Re: Spray Foam Gun
gasoline may eventually disolve it,not sure
some guys use heat...like a propane torch and ''burnout'' the foam in the metal parts,ive never done this
the higher quality guns are teflon coated on the inside i think
even if your can is empty always leave it on the gun
Old 11-15-2010, 08:15 PM   #8
wardy's Avatar
Trade: Contractor
Re: Spray Foam Gun
I picked up a Hilti foam gun at HD on clearance for $40 and every can of foam and cleaner that they had at .48 cents a piece. I couldn't believe why they would have them for so cheap. Went back next day and they where back at the same price. That was the happiest I have ever left that place!
The gun has been great for over a year. I use to clean it between each can of foam, but haven't run any cleaner through it in probably 6 months. I do the same as everyone else. Make sure there is always a can on it and clean off the tip when it dries.
Totally worth the money for the control over the foam and not worrying about the Great Stuff leaking all over the place while your using it.
wardy is offline
Old 11-15-2010, 08:28 PM   #9
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
Re: Spray Foam Gun
we've had similar problems, but we didn't follow the directions.........still learning though. I think the guns are good.
New gun, new can.......use it then turn it off, they say to store it can down, gun up........run the cleaner between cans and always store with an attached can of foam.........don't clean the end with a utility knife.
IMO, the disposables are a huge waste of $$$ unless you can empty it right away. Maybe someone has a trick to re-using disposables.
WNYcarpenter is offline
Old 11-17-2010, 10:25 AM   #10
Andrew M.'s Avatar
Rewards Points: 150
Re: Spray Foam Gun
MEK should dissolve the foam, or Carb cleaner,Berryman's is very good
Andrew M. is offline
The Following User Says Thank You to Andrew M. For This Useful Post:
tcleve4911 (11-17-2010)
Old 11-17-2010, 04:54 PM   #11
Wayfarer Doors's Avatar
Trade: windows and doors/ construction supervisor
Rewards Points: 150
Re: Spray Foam Gun
leave the can on, I use cleaner only if I get some foam on my clothes or to clean out a really good tip extender. I've never seen anything clean dried foam.
typically replace my gun every year, but go through 100 plus cans with it.
found a new supplier that gives a free gun with 3 cases of foam.
http://www.youtube.com/watch?v=o54VBPytBaI (foam gun maintenance video)
Wayfarer Doors is offline
Old 11-18-2010, 08:59 PM   #12
Remodelor's Avatar
Trade: Bath Remodeling
Rewards Points: 250
Re: Spray Foam Gun
Originally Posted by tcleve4911 View Post
Really?
Acetone will dissolve it while it's still wet, if you don't like yellow stains on your hand for a week.
Goof off or other petroleum distillates should dissolve it after it's dry.
Remodelor is offline
Old 11-19-2010, 06:39 AM   #13
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 812
Re: Spray Foam Gun
get some of your wifes or girlfriends fingernail pollish remover , not the scented stuff though, the good old acetone stuff!
dave_dj1 is offline
Old 11-19-2010, 10:00 AM   #14
ParatusFoam's Avatar
Trade: Spray Foam Insulation
Re: Spray Foam Gun
Carb Cleaner is a great one, although it is somewhat tough to get off once the foam is dried. There is also a product called NMP which works incredibly well, but it will eat away and some plastic and most rubber parts, so you must be careful when using it. *** sells NMP, so get a hold of them if you want to try a gallon of it, it is pretty cheap.
Last edited by Tinstaafl; 11-19-2010 at 06:41 PM. Reason: Vendor self-promotion prohibited.
ParatusFoam is offline
Old 11-23-2010, 12:34 AM   #15
skipdow's Avatar
Trade: window and door installer
Rewards Points: 75
Re: Spray Foam Gun
I have tried almost every gun on the market and can name the flaw with every one. We go thru a LOT of foam and have found the Hilti guns have the most control and the least issues or problems IF you treat it right.
The one that Tom uses is my second favorite.
skipdow is offline
Old 11-23-2010, 09:55 PM   #16
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
Send a message via AIM to WilsonRMDL
Re: Spray Foam Gun
laquer thinner will clean it out, when i was subbing for pella we used the $100+ guns and just used laquer thinner to clean them when the tips/barrels would get clogged up from a new guy taking the can off at the end of the day
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
The Following User Says Thank You to WilsonRMDL For This Useful Post:
tcleve4911 (11-23-2010)
spray foam voiding damage contract sonalamp Insulation 1 09-08-2010 02:11 PM
Soy Based Spray Foam ApgarNJ Insulation 9 08-05-2010 09:36 AM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
spray foam quesion mikeybobo Insulation 1 06-16-2009 09:40 AM
foam spray gun vs canned foam AustinDB Tools & Equipment 4 12-03-2008 08:30 AM
