Trade: Interior Trim
Sliding Miter Saw?
I'm sure these have been discussed before but I have a question pertaining to my use? I am looking for a sliding saw for purely cutoff work, 90 degree and no beveling so I don't care about things like angle stops and laser alignment and such. The only requirement I have is the ability to cut true and smooth through up to 12" stock that can run up to 1-1/2" thick, from poplar to oak and maple, etc. Can anyone steer me right? Thanks, Rod.
I like Green things
Re: Sliding Miter Saw?
Get a Radial arm saw. Way better than a SCMS for just straight consistant cross cuts.
#3 | |
Re: Sliding Miter Saw?Quote:
![]() Agreed
i use a RAS in the shop for straight cuts or a festool TS55 in the field with my SAL-MFT.
... i haven't finish my glass of green kool-aid yet - still not sold on everything they make.
BSA Renovations - Restoration and Renovation Specialists serving New Jersey's Bergen County. Bergen County's Premier Home Maintenance Provider. |
I like Green things
No Neo, I just cant bring myself to plop down 1300.00 bucks plus about another 400.00 in accessories for a dang miter saw when My Bosch works great.
I like Green things
Plus like you and I allready said he needs a RAS for that kind of work. Or a big Omga!! Those are kind of expensive.
Trade: carpenter
I like the makita 10" slider.
Has worked well for a couple years framing |
I could be wrong but I don't think a 10" can cut 12" stock. I believe my old DeWalt 12" could cut just over 13"
topsail's trimcat
the newer dewalt 10" can cut 12", im not sure of this but i think the rigid can as well but dont quote me on that
putting down subfloor with glue and screws, well i saw dr. smith and the robot too , i had a martian burger and a sonic shake |
Palisade Point Const.
My older 10" makita can cross cut a 2x12 with room to spare.
Trade: carpenter
we can cut 11 7/8" tgi with our 10"
A small saw isn't going to consistantly cut square, fast or very long given the parameters. A 12" Delta Contractor grade RAS will do it fast and all day long.
Want one? $150, cast iron and copper wound motor, 110/220V, could use a new deck. I'll even throw in a couple of blades. You pay shipping. PM if interested.
Thanks for the replies guys. The vast majority of the work this saw would need do is within 6" width and less, maybe 5% of use would need the slide capability, but it is better than flipping and flopping. I'd just like a 12" saw that runs true across the width of a 12" board with no shimmy. A RAS would do the job, but would be more than enough on most occasions. Rod.
You can get radial arm saws that are about the same size as a sliding miter saw. If all your cuts are square cuts, it really is the tool for the job. Are you looking for a stationary saw, or one that you can take with you to jobs?
IMHO, More is always better. Buying a minimal machine and pushing it to it's limits just means another ride to the store to buy another one at some time. Buy oversize and it will last a lifetime. Also not wander as much.
I do agree, more is better plus 10%. The other issue is shop space is at a premium right now, and until I can spread out a little.......the slider may have to do for now.
If it's for a shop, get a nice big used radial arm saw and make the room for it. It will be cheaper than a sliding miter saw since it's used and considered somewhat old fashioned, and it will be good quality because tools back then were built solid to last. Not to mention, it will be big, so should you one day need that capability, you will have it. The only thing that would be bad about it is if you have to take it to the job, because it won't be light.
| Amazon has got the Denali Miter Saw Stand on SALE for $65.89 delivered!!! | tnb | Tools & Equipment | 7 | 10-28-2008 05:07 PM |
| Blade Wobble New Miter Saw | balanceact | Finish Carpentry | 7 | 06-03-2008 09:12 AM |
| Hitachi sliding compound miter saw | A.W.Davis | Tools & Equipment | 14 | 02-01-2007 07:53 PM |
| Best Table saw and sliding miter saw. | wackman | Carpentry | 42 | 08-19-2006 07:04 AM |
| Hitachi C12LSH 12" Sliding Miter Saw | Leo G | Tools & Equipment | 7 | 07-20-2006 01:21 AM |
