Siding Brake
Old 05-24-2012, 12:58 AM   #1
timberrat's Avatar
Trade: general contractor, finish contractor
Rewards Points: 25
Siding Brake
Thinking about buying a used siding brake. Its a tapco pro lll it has a 14"throat and is 10'6" long. Its going to auction sat.
I used it and it seems great will make a 3/8 bend! Most I have used will only do 1/2. Has just a slight bit of sag in it but doesnt seem to bother it. And the cutoff tool worked great with no curl.
So my question is what are your thoughts on this model? and what is a fair price for it?
timberrat is offline
Old 05-24-2012, 01:08 AM   #2
VinylHanger's Avatar
Rewards Points: 6,924
Re: Siding Brake
I like mine. I have had it forever it seems. Mine has a slight reverse sag where some sheetrockers decided to throw it on top of a pile of scrap. It still works fine.
If it works and is clean, I wouldn't go much above 350-500 unless you really need it. They show up around here for that price all the time without the sag.
VinylHanger is offline
Old 05-24-2012, 08:56 AM   #3
Perfectionist
MF Custom's Avatar
Trade: Custom Carpentry
Rewards Points: 764
Re: Siding Brake
I like mine too. The Tapco pro 3 14" 10'6"works well and is not too big. $350 is a steal in my opinion... most used pro 3s around here would sell for $700 plus.
MF Custom is offline
Old 05-24-2012, 09:12 AM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 296
Re: Siding Brake
They are a pretty good brake. With the cutoff tool which is around 300 new 500- 700 would be a good price. Who knows at an auction you could walk away alot cheaper too.
It is pretty hard on a long piece to make that small of a bend with out working things. Not saying you can't just takes work. If it has been taken care of fairly you should be happy with it.
Mines a Black Max , but I bend steel too.
Randy Bush is online now
Old 05-24-2012, 09:56 AM   #5
SC sawdaddy's Avatar
Rewards Points: 1,018
Re: Siding Brake
I think I paid $500 for mine about 6 or 7 years ago. Its a Tapco Pro II. Its paid for itself many times over. I could have made a lot more money with it if I had rented it to every person thats asked me to "borrow it."
No, you cant hold my hammer. Where is yours?
SC sawdaddy is offline
The Following User Says Thank You to SC sawdaddy For This Useful Post:
superseal (05-24-2012)
Old 05-24-2012, 10:43 AM   #6
Perfectionist
MF Custom's Avatar
Rewards Points: 764
Re: Siding Brake
For small bends less than 5/8" back it up with a piece of scrap aluminum under it.
The Following User Says Thank You to MF Custom For This Useful Post:
VinylHanger (05-24-2012)
Old 05-24-2012, 11:44 AM   #7
Re: Siding Brake
I forgot it came with the cutoff tool. I don't like using one, but if you do, then I would go a bit higher for sure.
Old 05-24-2012, 06:31 PM   #8
Remodeler
mike d.'s Avatar
Trade: Professional Remodeler
Rewards Points: 272
Re: Siding Brake
are making seams or hems that important? My windy tapco dosen't do that....I think
mike d. is offline
Old 05-24-2012, 06:57 PM   #9
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
Re: Siding Brake
properly adjusted pro should have no problem bending 1/4-3/8''.if you find the middle slips out look for a broken bolt or pin at the cam
break shouldn't need to be adjusted tight,that leads to faster wear,i have the non adjustable cams in mine and 5 or 6 years later will do 3/8'' no prob,and i can lock my brake with one hand anywhere along it's length without using the loop handle
it's perfect
Tom Struble is offline
Old 05-24-2012, 07:00 PM   #10
Trade: siding
Rewards Points: 4
Re: Siding Brake
yes..
Old 05-24-2012, 07:56 PM   #11
Perfectionist
MF Custom's Avatar
Rewards Points: 764
Re: Siding Brake
it's perfect
Tom, if I try and bend any less than 1/2" or if the material is just short of the vinyl strip in my Pro 3 it tends to want to grab the edge of the coil and push the material straight back in instead of fold it up? whats your trick?
Old 05-24-2012, 07:59 PM   #12
Randy Bush's Avatar
Rewards Points: 296
Re: Siding Brake
Yes. please do tell Tom.
Old 05-24-2012, 07:59 PM   #13
Trade: siding
Rewards Points: 4
Re: Siding Brake
put the small bend in the brake and the long part out
Old 05-24-2012, 08:02 PM   #14
Gary H's Avatar
Rewards Points: 2,342
Re: Siding Brake
Tom that is a good answer, but i think you should have made them take the long way around before you told them that priceless gem of info.
Gary H is offline
Old 05-24-2012, 08:04 PM   #15
Trade: siding
Rewards Points: 4
Re: Siding Brake
i thought it was common knowledge
Old 05-24-2012, 08:08 PM   #16
Perfectionist
MF Custom's Avatar
Rewards Points: 764
Re: Siding Brake
Tried that too but still tends to slip a bit at anything under 3/8" Best trick I have found for small bends is to back it up with a scrap piece of coil under it.
Tom Struble (05-24-2012)
Old 05-24-2012, 08:19 PM   #17
Trade: siding
Rewards Points: 4
Re: Siding Brake
the common reaction when the brake slips say at the middle is to adjust the center cam to close tighter,instead of that try adjusting the cams on each side of the center cam a little looser
Old 05-24-2012, 08:57 PM   #18
Perfectionist
MF Custom's Avatar
Rewards Points: 764
Re: Siding Brake
The way I adjust my brake is with a small 1 1/2"- 2" wide strip of aluminum locked under each cam and I adjust to achieve equal pressure at each cam. Is there a better way?
Old 05-24-2012, 09:14 PM   #19
Trade: siding
Rewards Points: 4
Re: Siding Brake
no thats where you start but it's sometimes difficult to judge ''equal pressure'',as you use it you will find where and what needs tweeking
like i said my current brake has solid no adjusting cams which means the jaws meet where they are supposed to along it's entire length,which is what your trying to achieve by adjusting the cams,remember the adjustment screw is like a ''shim'' and sometimes we shim one too high trying for a tighter grip when really we should shim down on either side...this making sense?
Old 05-24-2012, 09:47 PM   #20
Perfectionist
MF Custom's Avatar
Rewards Points: 764
Re: Siding Brake
Yup... will be bending coil tomorrow and will adjust where needed. Stop by if your in Ringwood I'm working in behind the old Promart.
bent siding brake eric wright Tools & Equipment 25 01-21-2012 01:49 PM
Looking for a siding brake MA, CT, or RI mikedn Contractor Swap 0 08-07-2011 11:21 AM
Looking for a siding brake in KC ExtremePride Contractor Swap 2 01-21-2011 05:01 PM
siding brake Artworks Windows, Siding and Doors 5 08-22-2010 08:31 PM
ABC Supply Co. Inc. Acquires Chesapeake Siding and Roofing Grumpy Roofing 0 03-03-2009 09:40 AM
