Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 01-02-2007, 04:13 PM   #1
not workin for the man...
Trade: Remodeling contractor
Send a message via AIM to fastg60
shocking discovery... rigid sander and vac...
when i use my rigid random orbital sander and my small rigid vac. i get a recurring small spark when i touch the vac hose... it's not quite a 110 jolt, but a pretty good cold-winter-day-shuffle-across-the-carpet shock. it will build up and discharge about every second or two... neither tool has a grounded plug and the only connection between the two units is the plastic hose.
any ideas?
Around The House
Remodeling and painting.
fastg60 is offline   Reply With Quote
Old 01-02-2007, 05:35 PM   #2
Custom Builder
Glasshousebltr's Avatar
Yes......what time zone are ya in?.......cause it sounds like your pretty close to the twilight zone.
Bob
Bob
Glasshousebltr is offline   Reply With Quote
Old 01-02-2007, 05:42 PM   #3
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Hire a helper. You can figure out the rest. I have used Porter Cable's random orbit sander for years with Ridgid shop vac's and no problem, maybe you need to mix the brands?
dougchips is offline   Reply With Quote
Old 01-02-2007, 08:06 PM   #4
Painting Contractor
DelW's Avatar
Trade: Painting Contractor
My Shop Vac will do that to me once in a while. I can't find any ryme or reason to it. I'm thinkin the twilight zone thing is soundin pretty good.
If love is blind, why do they make Lingerie?
DelW is offline   Reply With Quote
Old 01-02-2007, 08:25 PM   #5
Ruane Woodworks,LLC
pruane's Avatar
Trade: Finish and Custom Trim
sounds like static from the dust and hose. All plastic Vac?
pruane is online now   Reply With Quote
Old 01-03-2007, 06:56 AM   #6
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
It's a static electric shock. My shop vac will do it too me from time to time when I'm picking up alot of wood dust and chips.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 01-03-2007, 05:31 PM   #7
Greg Di's Avatar
Trade: Remodeling & Decks
The better portable shop vacs that are tool triggered come with anti-static hoses off the bat.
In a pinch, I guess you could rig some sort of ground wire to the system someplace.
Just be careful because fine sawdust and sparks usually=FIRE!
Greg Di is offline   Reply With Quote
Old 01-13-2007, 01:02 AM   #8
GC / Remodeler
Trade: General Contractor/Remodeler
Send a message via AIM to dshcontracting
definately static electicity. thats why you ground dust collection hoses in a shop enviroment. Try sucking up rock wool with your shock vac. It's a little more alarming how good of a shock you get.
Dan
dshcontracting is offline   Reply With Quote
Old 01-13-2007, 09:42 PM   #9
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
i was running a very cheap shop vac on my mitre saw, and had built up enough charge to fry the motor. It was weird to watch. The dust around my saw would stand up, and go to the hose, and then all of a sudden, the dust collapsed and then so did my shop vac.
Real nice guys
King of Crown is offline   Reply With Quote
