Scored Piston...Repair Or Replace Saw
Old 07-23-2009, 12:15 PM   #1
The Deck Guy
Greg Di's Avatar
I bought a Partner K950 14" saw off eBay a couple of months ago. It was used but ran "decently" for the $400 I paid for it.
I used it for two projects (limited use) and it crapped out in the middle of cutting a slab yesterday.
Brought it to a VERY GOOD 2-stroke place and they took apart and told me what we both thought...scored piston on the exhaust side.
I can buy a new piston and cylinder for $200 and replace it, OR, I chuck the saw (which I've used twice) and drop $700+ on a new saw.
I don't know how good the old saw will be even with a new piston and cylinder. Will it be "good as new"? I don't know????
Opinions please.
Greg Di is offline
Old 07-23-2009, 12:31 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Re: Scored Piston...Repair Or Replace Saw
Keep it and fix it. You will know it is right then.
I bought 2 old partner's from my brothers boss. 2 benny's apice. Replaced a piston in one and sold it. Got the second one for almost free.
Those things will last you a good long time.
WarnerConstInc. is offline
Old 07-23-2009, 12:47 PM   #3
The Deck Guy
Greg Di's Avatar
Just talked to the guy and he says it's about 3 hours of labor to fix it at $80 per hour. Ugh....Now the decision is even harder to figure out.
Greg Di is offline
Old 07-23-2009, 01:10 PM   #4
rustyjames's Avatar
I'd sell that one on ebay "as is" and get another one. Or find someone who's willing to repair it for less. It's a saw, not a Mercedes. You can probably find a better deal on the piston/cylinder kit too.
rustyjames is offline
Old 07-23-2009, 02:12 PM   #5
Tech Geek
WarriorWithWood's Avatar
Trade: Property Management/Facilities Manager
x2.
-Dennis
www.bowmanch.com
WarriorWithWood is offline
Old 07-23-2009, 02:17 PM   #6
BCConstruction's Avatar
Trade: Construction
Opinions please.
Can you not get the new head and piston and do it your self? im sure you could pick up the parts pretty cheap on line.
BCConstruction is online now
Old 07-23-2009, 03:11 PM   #7
The Deck Guy
Greg Di's Avatar
The parts are $230.
I just don't know how complicated it will be to do. I have zero experience working on engines of any type.
Greg Di is offline
Old 07-23-2009, 03:12 PM   #8
The Deck Guy
Greg Di's Avatar
Originally Posted by WarriorWithWood View Post
x2.
That's funny!
I knew buying a used cut-off saw was hit or miss since they all have very limited life cycles. I was hoping to get more than 2 jobs out of my $400 investment though!
Greg Di is offline
Old 07-23-2009, 07:23 PM   #9
I like Green things
It's pretty easy to pull the jug, knock out the wrist pin, install new piston, wrist pin, rings, gasket and jug. I really think you probably have enough tools to take care of it yourself.
Old 07-23-2009, 07:32 PM   #10
raydzi's Avatar
Trade: general contractor
a plus is if u do it yourself u gain all this knowledge.on how to change out a jug and piston
raydzi is offline
Old 07-23-2009, 11:43 PM   #11
Inner10's Avatar
Trade: Control Systems
And if you bunk it up your out an additional 230 bucks lol.
I'd look around for a better price on the piston, 230 outch!
Inner10 is online now
Old 07-23-2009, 11:57 PM   #12
I like Green things
http://www.discountonlineparts.com/c...%20Kits&id=107
Old 07-24-2009, 12:55 AM   #13
The Deck Guy
Greg Di's Avatar
Originally Posted by WarnerConstInc. View Post
Yup...that's the place!
Greg Di is offline
Old 07-24-2009, 01:33 AM   #14
I like Green things
I think you would be out less money fixing it your self. Get a owners manual. I bet you can do it. Or just ship it to me, no firm date on return delivery, however.
Old 07-24-2009, 10:50 AM   #15
rustyjames's Avatar
I can't believe the price of those Partner parts. I have a Stihl TS400 and the cylinder kits can be bought for less than 100.00. I think the Stihl is a much better built saw, too.
Old 07-24-2009, 05:23 PM   #16
jiffy's Avatar
Trade: General Construction
Bad gas is usually the main culprit in gas saw issues. I have seen way too many over the years. Synthetic 2 stroke oil also helps to reduce the heat in the air cooled engines.
jiffy is offline
Old 07-24-2009, 09:17 PM   #17
Trade: Construction
A good oil is honda HP2 oil. I use it on my rc 26cc engines that put out over 6hp and can run as high as 21000rpm and i even run it at 32:1 most times. If the oil functions well with them rpms it will run well on any 2 stroke. It's also a good idea to run higher octaine fuel and treat the fuel with sta-bil even if you think you are gonna use it often. Stops the fuel from gelling up and carb from blocking up. Also remember to clean and re-oil the filter often.
Porch Column Repair mpt1123 Historical Restoration 5 01-11-2010 07:33 PM
counter top repair? te12c02w General Discussion 7 03-23-2009 09:44 AM
Rheem Recalls to Repair Oil-Fired Furnaces Due to Fire Hazard MechAcc HVAC 0 01-22-2009 06:10 PM
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 09:19 AM
Repair or Replace? Greg Di HVAC 12 02-02-2007 10:36 PM
