Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 09-19-2009, 11:44 AM   #1
finish carpenter
sanding discs
today i was at a woodworking supply and they had the rep for blueline sandpaper there giving demo and info on sandpaper.
interestingly he mentioned how a guy had told him their sandpaper was no good. responded where do you keep your sandpaper. buddy responded that he keeps it in his unheated garage
basically the point he wanted to make is that i guess you have to keep sandpaper at above 60 deg at all times otherwise the resins that bond it to the paper break down
cutting some wood
woodworkbykirk is offline   Reply With Quote
Old 09-19-2009, 12:35 PM   #2
Steve
Trade: Remodeling and Custom Cabinets
I use Mirka Gold disks, never had a problem
BACKWOODS is offline   Reply With Quote
Old 09-20-2009, 12:52 AM   #3
Faking my Way
TBFGhost's Avatar
Trade: Architectural Trim and Punchlist Work
.....really?????
TBFGhost is offline   Reply With Quote
Old 09-20-2009, 07:22 AM   #4
I had been using the Mirka because I had bought a bulk quantity of it. Ran short of a few grits and picked up some of the Norton brand. It has outperformed the Mirka hands down. Usually I'm changing disks out frequently on oak but the Norton keeps a nice edge far longer than the Mirka.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas
jaros bros. is offline   Reply With Quote
The Following User Says Thank You to jaros bros. For This Useful Post:
BACKWOODS (09-20-2009)
Old 09-20-2009, 06:28 PM   #5
finish carpenter
normally i use norton but for finer grits i go to blueline. mainly do to price and availability. i can get the 25 packs for 15 dollars at one supply where as others want $20 for 20 packs of the same brand
cutting some wood
Sanding and Finishing Engineered Hardwood AcademyHardwood Flooring 3 08-06-2009 02:38 PM
sanding concrete Traditions2 Painting & Finish Work 10 01-31-2009 03:33 PM
sanding sealer on windows ? sprayer48 Painting & Finish Work 8 10-23-2008 11:10 PM
Microplane sanding discs JPhelps Finish Carpentry 1 10-13-2007 10:16 AM
Drywall Sanding Sponges? Abrasive Dan Drywall 6 06-14-2007 04:35 PM
