Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 04-28-2009, 10:40 PM   #1
improving homes
Trade: Roofing/Remodeling
router table plans
I don't do much routing but occasionally I need to pull out the routers. I would like to build a router table but since I haven't used a table much I don't really know what plan is good or what features I should include. I would like this to be portable and budget friendly since I won't use it that much but also want something that can do a variety of things when I need a router table. Does anyone have any plans that they can share or pics of a nice homebuilt router table? Thanks for the help
platinumLLC is offline   Reply With Quote
Old 04-29-2009, 05:55 AM   #2
There's a good one at Fine Woodworking. Google Fine Woodworking and Rock Solid router table, it should come up.
I used that design for the top and altered it a bit for the base: shorter, detachable legs and base to make it portable. Also put a handhold on the bottom side of the top to ease carrying.
It's now sturdy and maneuverable. I like it.
Served me nicely so far. Better than the little mini tables PC, Bosch and all the others sell.
The Forest is offline   Reply With Quote
Old 04-29-2009, 07:14 AM   #3
Carpenter
RizzoMaryland's Avatar
If you aren't using it much or you need to transport it around, then I would purchase a pre-built collapsible table.
You'd be hard pressed to make a table better than this one that is collapsible, easy to store, with decent features for $200. However may need to fasten it down when using.
http://www.woodcraft.com/product.asp...&FamilyID=6536
Larger variations are also available out there.
"An idea is salvation by imagination"
Frank LLoyd Wright
RizzoMaryland is offline   Reply With Quote
Replacement fence for Porter Cable 698 router table Panzer5 Carpentry 4 04-10-2009 10:47 AM
Bad Home Plans Cost US! NC2X4 General Discussion 0 02-28-2009 01:34 AM
parts for dial n angle tapco saw table LMS CONST. Tools & Equipment 0 10-27-2008 09:36 PM
Bosch Router Table dayspring Tools & Equipment 4 06-14-2006 09:31 PM
Router table magnum Tools & Equipment 14 01-01-2006 12:52 AM
