#21 |
Trade: General Construction
Re: Removing A Stuck Bit From Dewalt Impact Driver?
Find a Dewalt parts diagram online and the fix should be easy as following the instructions.
#22 |
Trade: Pipe Cleaner
Grab that SOB and chuck it as hard as you can against a slab of concrete. It won't get the bit out but you will feel much better!
#23 |
Staggs Construction
Trade: carpenter
I have a guy that works with me that had a new nano impact that he bought off of ebay, broke a bit off inside of the 1/4 chuck (where there was nothing to grab), took it to a repair shop and they wanted $100 because they said they would have to replace the chuck. So he just bought another one for $109.
#24 |
Palisade Point Const.
I would try tapping a screw into the middle of the bit and use that to pull it out.
#25 | |
Trade: Squirrel Handler
Re: Removing A Stuck Bit From Dewalt Impact Driver?Quote:
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
#26 |
Re: Removing A Stuck Bit From Dewalt Impact Driver? |
#27 |
Trade: trim carp
You can probably drill it with a cobalt bit.
#28 |
Trade: High Pressure Air
After reading this I had to double check my Milwaukee M18 impact and it is set up with a detent coller that slides toward the bit to release. Which would make it hard to use the method illustrated by Mickeyco. Had I thought of this it would have been a consideration when choosing an impact. How about starting a list of which impacts are setup with detent collers that pull BACK so you could vice up the bit and pry against the sleave holding the bit?
#29 |
Trade: Control Systems
I've gotten plenty of bits stuck in my impact...the secrete is don't use crap bits. I clamp the bit in the vice and then put the impact in reverse, let it anvil a few times while you pull the collar forward and pull the impact back using your body weight. Be caseful not to fly backwards when the bit comes out.
The worst culprits are the Black and Deckar get a million bits that fit nothing for 5 bucks....they begin to strip in the chuck and really get fudged in there. I bought a Hilti bit holder and bit set and never had a problem again....until I need a longer bit and have to use a Rona Industrial POS. |
#30 | |
Trade: Electrician
Edit: with an ordinary drill, not impactor. Last edited by Pekka; 03-26-2009 at 07:29 AM. |
#31 | |
You can also buy really really hard bits that this probably wouldn't work on, but they aren't the norm. |
| The Following User Says Thank You to TempestV For This Useful Post: | Pekka (03-27-2009) |
| uh oh, half broken cordless impact driver | woodworkbykirk | Tools & Equipment | 3 | 02-26-2009 07:03 AM |
| Kitchen Install *( impact driver ) | MikeNeufeld | Tools & Equipment | 32 | 02-13-2009 07:03 PM |
| Dewalt impact driver.....DC827N | frain21 | Tools & Equipment | 6 | 10-18-2008 05:31 PM |
| Bosch 10.8v impact and driver...Jac Pac system | jeffaah | Contractor Swap | 0 | 08-19-2008 05:41 PM |
| Do you use an impact driver? Quick survey help would be very much appreciated. | cohaver | General Discussion | 4 | 04-02-2008 07:20 PM |
