Removing A Stuck Bit From Dewalt Impact Driver?
Old 03-11-2009, 07:53 PM   #1
Tim C.'s Avatar
Trade: Fencing and landscaping
I have a dewalt impact driver that one of my guys got a screwdriver bit stuck in. You can pull out on the collar, but the bit will not release. i have tried wd40 etc to lubricate it. I did not know if there is a way to take the collar assembly apart to get the bit out. The owners manual is not any help.
Tim C. is offline
Old 03-11-2009, 08:01 PM   #2
dkillianjr's Avatar
Re: Removing A Stuck Bit From Dewalt Impact Driver?
I have had the same problem. What has worked for me was either tapping the bit and pulling it out with some pliers. Or grab the bit with some pliers and impact it in the oposite direction you were useing when it got stuck, the impacts should loosen it up.
dkillianjr is offline
Old 03-11-2009, 08:02 PM   #3
Five Star's Avatar
try to put drill in reverse mode and hit the trigger then forward mode,
if that doent work tap the tip on the drive way but dont slam it..it should release!
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
Old 03-11-2009, 08:15 PM   #4
Al Smith
A W Smith's Avatar
the hex shank is bent. I had that happen twice when i dropped or stepped on my rigid impact driver. the shank bends and the collet will not clear the stepped detent of the hex driver/bit. only solution is an extreme tug of war with a vice. tapping while pulling helps with the aluminum shanks. don't know if it will help with a steel shank.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 03-11-2009, 08:16 PM   #5
Palisade Point Const.
TempestV's Avatar
if the bit has any kind of bulge to it that you can hook with a hammer claw, then you can pull it just like pulling a nail. I've done that a few times. Just hold back the collar and yank it out of there.
TempestV is offline
Old 03-11-2009, 08:30 PM   #6
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
Aand once you get it out , throw that bit away. It is the bit ,not the tool.
knucklehead is offline
Old 03-11-2009, 08:41 PM   #7
Professional Instigator
rbsremodeling's Avatar
I tie a chain around the drill and hook it to my truck.
tie a chain around the hex head and tie it to the bobcat.
Get into the truck and floor it pop right out
rbsremodeling is offline
The Following User Says Thank You to rbsremodeling For This Useful Post:
dakzaag (03-11-2009)
Old 03-11-2009, 08:48 PM   #8
Steve
OCRS's Avatar
Try vice-grips on the bit and hit the grips with a hammer.
OCRS is offline
Old 03-11-2009, 09:24 PM   #9
I like Green things
WarnerConstInc.'s Avatar
Stop using an impact driver.
WarnerConstInc. is online now
Old 03-11-2009, 09:37 PM   #10
Williams Ex Co's Avatar
Trade: Excavation, land clearing, sewer/water
What OCRS said but be sure to pull the lock collar too.... Might help to have someone holding the driver and pulling the collar while you hold the visegrips and wail away.....
Williams Ex Co is offline
Old 03-11-2009, 09:39 PM   #11
Dip the tip in motor oil overnight pull it out with a vise grip in the am. If it is still stuck heat it up a bit
Old 03-11-2009, 10:00 PM   #12
The Deck Guy
Greg Di's Avatar
If Festool made one, you'd have it. Don't lie to me.
Greg Di is offline
Old 03-11-2009, 10:10 PM   #13
TempestV's Avatar
but what would you do if a bit got stuck in your C12?
TempestV is offline
Old 03-11-2009, 10:23 PM   #14
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Take it back to 'Casa Depot' tell them it's a POS and get a new one
Chris
Chris Johnson is online now
Old 03-11-2009, 10:35 PM   #15
I like Green things
Damn Greg!!
I have 2 Makita's, a Bosch and a compact Bosch Impactor.
I have not touched one of those in about 8 months.
If Festool make one, I am pretty sure (83.87%) that I wouldn't.
I just dont like all the noise anymore.
I must be getting old.
Old 03-11-2009, 10:37 PM   #16
I like Green things
I honestly don't think that would happen.
The shanks are completely different than the 1/4" hex.
If it does I will report it.
Also- I had numerous bits get stuck in my Bosch, it always twisted them.
Just beat the crap out of it, it will come out.
My 12 and 14 volt Mak's never did that.
Old 03-11-2009, 11:15 PM   #17
mickeyco's Avatar
Trade: Squirrel Handler
Use a sleeve or shim if the release collar comes out to far.
mickeyco is offline
Old 03-11-2009, 11:34 PM   #18
Al Smith
A W Smith's Avatar
only problem with that illustration is you need to pull the collar out to release the detent.
Al Smith
Old 03-11-2009, 11:40 PM   #19
mickeyco's Avatar
I've done it, it works.
mickeyco is offline
Old 03-11-2009, 11:55 PM   #20
Tim C.'s Avatar
Thanks everyone for your replies, I will try your ideas tomorrow. I have already tried the tug of war ideas with the vise grips. I was worried if i pulled to hard I would mess up the shaft or something internally and ruining the tool with to much force?
Tim C. is offline
uh oh, half broken cordless impact driver woodworkbykirk Tools & Equipment 3 02-26-2009 07:03 AM
Kitchen Install *( impact driver ) MikeNeufeld Tools & Equipment 32 02-13-2009 07:03 PM
Dewalt impact driver.....DC827N frain21 Tools & Equipment 6 10-18-2008 05:31 PM
Bosch 10.8v impact and driver...Jac Pac system jeffaah Contractor Swap 0 08-19-2008 05:41 PM
Do you use an impact driver? Quick survey help would be very much appreciated. cohaver General Discussion 4 04-02-2008 07:20 PM
