Recommendation For Drilling In Concrete
Old 10-09-2009, 11:00 PM   #21
I builds'em
Winchester's Avatar
Trade: Renovations & Decks
Re: Recommendation For Drilling In Concrete
I used a Milwaukee SDS max to drill about 64 holes 1-1/2" wide, 7" deep last week.
With an SDS and carbide-tipped bits is a good combo. The bits last a long time too.
It did a great job, but was very awkward to drill the holes (was a wall). Especially since most of them were waist height and lower.
Winchester is offline
Old 10-10-2009, 12:02 AM   #22
13 Licenses & Counting
piercekiltoff's Avatar
Trade: Water well drilling & pumps
We used one of these to bore a 10" hole through 19ft of concrete with 3/8ths aggregate & 18 more feet of gravel & sand. Took all of 25 minutes.
For that site, we were using a CP 650WS with 825 CFM & 350 PSI compressor, 25,000lbs of down pressure and 30,000 pull back.
After 37ft, we switched to a 6" tricone, drilled and cased to 358ft total depth.
It's a drill, and we drilled concrete....so, not quite off subject
Pierce Kiltoff, CWD/PI, JKA Well Drilling and Well Pumps & Filter Supply - Map Facebook
Monroe, Washington, (360)-794-7300
Serving the Entire Seattle Area, including King, Snohomish, & Pierce Counties, WA
piercekiltoff is offline
Old 10-10-2009, 08:20 AM   #23
stp57's Avatar
Trade: carpenter/ handyman
Yup. Water does the trick. Either dip the bit in a bucket or use a spray bottle. I get months out of my bits that way.
Steve
Originally Posted by BCConstruction View Post
Make sure your using the correct drill to start with. A proper sds hammer drill will drill holes through concrete 10x faster than a cordless style hammer drill with a lot less heat. Use the smallest bit you have and work your way up. If it's a core drill bit then chose the correct size and drill away. But remember dont use core bits on hammer. You can also use water to keep the bits cool if you like.
stp57 is offline
Old 10-11-2009, 12:50 AM   #24
Colorado Fatboy's Avatar
Trade: Glazier 17 years. Now a Sparky in training.
Hilti TE 6-S rotary Hammer Drill! This drill is AMAZING, I have drilled thousands of holes in a very short time and it still works like new. Absolutely effortless in concrete! NO comparison to a cordless Dewalt 1/2" hammer drill. The bits just don't burn up like they do with the other drills. I've been using the same 1/4" bit for about 2 months and I use it several times a day. If I would have known about this drill before, I would have probably saved a lot of $$ in drill bits.
Colorado Fatboy is offline
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 46 08-07-2011 02:55 PM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 10:41 PM
Spalling concrete stabilization tsunamicontract Concrete & Paving 4 06-07-2009 08:51 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 05:18 PM
