Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 05-16-2009, 09:26 PM   #1
native floridian
jfranklin's Avatar
Trade: lic: Aluminum contractor. lic: Painting contractor
rebuild compound miter saw?
my dewalt 12" compound miter saw sounds like a handfull of granite rocks
fell in the motor while it was runnin. needs to be rebuilt with new bearings
and such. anyone ever rebuild one of these? i cant aford a new one right
now.
screen room, pool enclosure specialist
jfranklin is offline   Reply With Quote
Old 05-16-2009, 09:38 PM   #2
Faking my Way
TBFGhost's Avatar
Trade: Architectural Trim and Punchlist Work
Get one off Craigslist....
TBFGhost is offline   Reply With Quote
Old 05-16-2009, 09:42 PM   #3
Trade: trim carp
then sell yours on craigslist
m1911 is offline   Reply With Quote
Old 05-16-2009, 10:18 PM   #4
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Dont get another DeWalt.
WarnerConstInc. is offline   Reply With Quote
Old 05-17-2009, 05:01 AM   #5
framerman's Avatar
Trade: Framing, Custom Carpentry, Architectural Design
I've burned out 3 motors on the exact model. Either get another motor or a new SCMS. Check your belt also, the teeth could be stripped and cause that noise.
If one advances confidently in the direction of one's dreams,
and endeavors to live the life which one has imagined,
one will meet with a success unexpected in common hours
~Henry David Thoreau
framerman is offline   Reply With Quote
Old 05-17-2009, 09:00 AM   #6
now.
To be in this business, - - I'd say it's more like you can't afford not to get one right now . . .
Tom R is offline   Reply With Quote
Old 05-17-2009, 09:16 AM   #7
..........Check your belt also, the teeth could be stripped and cause that noise.
Check the belt before
you panic.
neolitic is offline   Reply With Quote
Old 05-17-2009, 09:28 AM   #8
Trade: interior millwork
it cost me 50 couple bucks including labor to replace the arbor bearing a few months back on one of my saws,well worth it
sounds like the same thing your describing
i too thought it was the belt,but after inspecting the belt it looked like new,by all means its worth repair as long as it still cuts true
trimman2 is offline   Reply With Quote
The Following User Says Thank You to trimman2 For This Useful Post:
jfranklin (05-17-2009)
Old 05-17-2009, 09:50 PM   #9
native floridian
jfranklin's Avatar
i have been getting by with my 10inch saw but it wont cut everything
Old 05-17-2009, 09:52 PM   #10
native floridian
jfranklin's Avatar
its been a great saw and still cuts true. it is my fault it got let in the rain
more than once in the back of the truck bad idea
Old 05-17-2009, 09:59 PM   #11
I still wouldn't get a dewalt.
The rain was a sign from the tool gods.
Old 05-17-2009, 10:11 PM   #12
Faking my Way
TBFGhost's Avatar
I have to say I do enjoy a DW706 I have been using. It is a DeWalt 12" CMS that one of the companys I sub in for uses. It has a MUCH better vertical capacity then my Bosch 12" slider and even the Bosch 12" CMS. The saw runs true, and pretty smooth....its not an outstanding saw that puts me in "awe" if you will but it does its job none the less....and it looks like it has not seen a pretty life either. However, I will use my Bosch where ever I can....but when it comes to vert cutting capacity the DW706 does something like 6 5/8 or something stupid....or at least that is what I measured IIRC.
Old 05-17-2009, 10:35 PM   #13
tomstruble's Avatar
Trade: siding
Warner cute pit in your avitarheres my guy cutting a scarf joint on some trim im doing
tomstruble is offline   Reply With Quote
Old 05-18-2009, 11:28 AM   #14
Thanks but, she's an American Bulldog!
Old 05-18-2009, 11:44 PM   #15
Trade: trim carp
Dewalt makes some decent miter saws
The Following User Says Thank You to m1911 For This Useful Post:
jfranklin (05-19-2009)
Old 05-18-2009, 11:49 PM   #16
Trade: Remodeling general
I've had a CMS 12" without the belt for 12 years and no trouble. And it sits on a dewalt track rack type stand which I love.
naptown CR is offline   Reply With Quote
Old 05-19-2009, 04:16 PM   #17
i have no problem with Dewalt miter boxs,or the compressor i have,i do have a big problem with the drills,compressor is a bit heavier than my Emglo but it doesnt trip breakers like the Emglo either
i will say if you run a Bosch miter box,and then a Dewalt,then you will see what the guys are saying about Dewalt
Miter folding with a cnc machine Gus Dering Finish Carpentry 34 11-01-2009 09:42 AM
Miter saw for framing Stubits Framing 5 04-25-2009 01:41 PM
Milwaukee compound slide miter saw sore thumb Tools & Equipment 36 02-18-2009 07:48 PM
Compound Miter Saw question KillerToiletSpider Tools & Equipment 7 08-08-2007 07:47 AM
Hitachi sliding compound miter saw A.W.Davis Tools & Equipment 14 02-01-2007 07:53 PM
