Real MAPP Vs Replacement Propylene High Temp Gas? - Tools & Equipment - Contractor Talk
Old 04-17-2011, 06:00 PM   #1
Electric_Light's Avatar
Trade: student again
MAPP was offered as a drop in alternative for propane for use in portable torches to get a higher temperature. It is a patented product and the only company making it decided to discontinue in 2008.
It was a blend of methyl acetylene and propane.
Now they have a substitute that's basically pure propylene.
How do they compare?
Electric_Light is offline
Old 04-17-2011, 08:10 PM   #2
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
Re: Real MAPP Vs Replacement Propylene High Temp Gas?
I still have a partial case of the actual MAPP cylinders on hand, so at the rate I use it, I probably won’t actually need to buy the newer MAP/Pro propylene stuff for quite some time.
But, here is what Thermadyne, the parent company of Victor/TurboTorch, has to say about it.
MAP//PRO, which is produced by Worthington Cylinders of Columbus, OH, has a higher flame temperature and better combustion intensity than propane, which enables professional users to complete their tasks more quickly. MAP//PRO also has a higher vapor pressure than MAPP resulting in better performance in colder temperatures.
"The effective BTU output is a measurement of the quantity of BTUs that actually go into the work piece when heated", said Paul Minter, VP / General Manager, TurboTorch."Our lab tests have revealed that MAP//PRO has approximately a 10% greater BTU output over Propane and a 14% less effective BTU output than MAPP. Given the technical advancements offered by TurboTorch products as the premium brand in the market, our torches maximize the performance of propylene based (MAP//PRO)."
DuMass is offline
Old 04-17-2011, 08:36 PM   #3
robert c1's Avatar
Trade: remodeler/gc
Rewards Points: 288
I've used the propleyne recently. I had good success with it, evenly heating some brass fixtures. Something I've struggled doing with propane.
It's not Mapp but it's definitely better than propane.
robert c1 is offline
Old 04-18-2011, 12:48 AM   #4
Too bad its $8 a canister for just a 10% higher BTU.
High Speed Cable & P.O.T. Separation? redzthredz Low Voltage 11 12-01-2009 04:09 PM
High Stack Temp Woes RopeaGoat HVAC 5 03-01-2008 08:43 AM
Houston Area Builders and Project Mgrs- Are you prepared for high tech homes HomeMedia Pros Business 10 02-19-2008 01:43 AM
High build, high gloss urethane rhinoguy Flooring 1 02-27-2007 05:28 PM
