Problem With Hitachi Air Compressor
Old 04-02-2006, 09:45 PM   #1
Redman's Avatar
Trade: Remodeling/Painting
Send a message via MSN to Redman
I have a 2 hp Hitachi EC11 air compressor and it runs fine, but when the compressor shuts when it get to 120 psi it starts to release all the air, seam like a valve is stuck open or something, anyone ever have this happen or know how to fix it. Thanks for the help.
Nick
One day at a Time.
Redman is offline
Old 04-02-2006, 10:20 PM   #2
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
Re: Problem With Hitachi Air Compressor
Nick
have you adjusted your preasure knob?
Real nice guys
King of Crown is offline
Old 04-02-2006, 10:40 PM   #3
Redman's Avatar
Yep , its not the pressure knob.
One day at a Time.
Redman is offline
Old 04-02-2006, 10:42 PM   #4
Heavy Weight Champ
Is that the oil model?
Real nice guys
Old 04-02-2006, 11:16 PM   #5
Redman's Avatar
yes,it is the oil model
One day at a Time.
Redman is offline
Old 04-02-2006, 11:34 PM   #6
Heavy Weight Champ
Then I cant help, sorry.
Real nice guys
Old 04-02-2006, 11:46 PM   #7
Blackhawk's Avatar
Trade: i am a small remodeling contractor been at this most my life
you sure it isnt the bleedervalve on the tank not closing fully just a thought ..
Blackhawk is offline
Old 04-03-2006, 12:31 AM   #8
Redman's Avatar
no, the tank will stop losing air once I shut the power off.
One day at a Time.
Redman is offline
Old 04-03-2006, 08:35 PM   #9
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
Have you checked to make sure you have not exceeded the pressure pop off valve? There should be a small brass pop off valve that has a ring in it that looks like a key ring. If you have pumped up too much pressure or it is weak it will pop off and release all the presure. Also there is a pressure release valve that is in the controll box that when the compressor quits pumping it releases the air on the piston so that when the pump starts again it is not starting against pressure. See if you can find these two things and check them.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 04-03-2006, 10:55 PM   #10
Redman's Avatar
yeah it has something to do with that valve, it use to release a little presure when the compressor shut off but now it release all the pressure in the tank. is there a valve that is stuck or be replaced.
One day at a Time.
Redman is offline
Old 04-04-2006, 06:56 AM   #11
Master Craftsman
Big Dave's Avatar
There is probably a little peice of trash in it causing it not to shut. You should be able to take it off and clean it or replace it if it is faulty.
Big Dave is offline
Old 04-04-2006, 08:12 PM   #12
Redman's Avatar
thanks for the help big dave.
Redman
One day at a Time.
Redman is offline
Hitachi air compressor Bill Tools & Equipment 2 06-11-2007 08:30 PM
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
Air Compressor and Power Inverter Question plazaman Tools & Equipment 0 12-18-2006 11:06 PM
Problem with sub with no contract signed kevjob Business 37 10-04-2006 11:36 PM
hitachi nv45 problem kmd Roofing 3 04-06-2006 03:28 PM
