Porter Cable 557 Plate Joiner
Old 10-18-2009, 01:13 PM   #1
krm's Avatar
Trade: Subcontractor
buying my first plate joiner need to know type 1,2,3,4,5, what is the difference
thanks Ken
krm is offline
Old 10-19-2009, 08:52 AM   #2
All ahead flank
Bill in VaBeach's Avatar
Trade: Kitchen and Bath Remodeling, Home Improvement
Re: Porter Cable 557 Plate Joiner
Porter-Cable is good, solid choice. I use mine frequently in cabinet making, completely pleased with its performance. Researched it thoroughly, and tried it against the DeWalt, and prefer the PC to DeWalt. Numbers refer to the biscuit sizes, from smallest, which are well suited to face frames, through largest sizes, which are used for table top glue-ups and sheet goods.
The PC kit includes two blades that allow you to match the biscuit to the job. Do some online research and ensure this is the joining system you want to use, instead of a Kreg jig for instance, or dowels.
The operator's manual is about average, could be better. It pre-supposes a working knowledge of this type of tool.
Bottom line: Very good tool for the price, and a good means of joining wood when medium strength joints are required.
Bill in VaBeach is offline
Old 10-19-2009, 10:16 AM   #3
Andrew M.'s Avatar
Early types 1, 2, I think, has some issues that require shimming. The fix by PC caused B&D to file suit on their DW fence patent. I believe type 4 which I have has no issues. Do a google search you will find details. Best for the money. has 2 blades so you can use smaller biscuits [FF]for Face frames and edging on narrow stock. I added some wet/dry sand paper to the fence face to reduce slipping, used spray adhesive, cut out with fine knife blade. Also, there is a bit of motor torque, so trigger first , let come to speed, then cut. A slow start like on the Routers would be an improvement, and the side plastic fence pivot plates could have been made in metal. I may buy a spare set as who knows what B&D will do with the PC lineup.
Andrew M. is offline
Old 10-20-2009, 04:52 PM   #4
krm's Avatar
well i wint with the PC made short work out of the cab on to the next job
thanks
Ken
krm is offline
Old 10-20-2009, 07:35 PM   #5
tccoggs's Avatar
I have used the cadillac of plate joiners, the Lamello Top 10. Its a nice tool, but I don't think the cost is worth it. If they were on the shelf next to one another, I would still reach for the PC.
tccoggs is offline
Old 10-20-2009, 07:38 PM   #6
Illusion of Perfection
CookeCarpentry's Avatar
I have an early DeWalt. Approx 12-15 yrs old.
I am just wishing it would die so I could get the PC. Only DeWalt tool I have purchased that I am not happy with - only found this out after using someone else's PC.
CookeCarpentry is offline
Porter Cable 371K 2 1/2" x 14" Compact Belt Sander dayspring Tools & Equipment 7 08-19-2009 01:51 AM
porter cable compact belt sander woodworkbykirk Tools & Equipment 17 05-03-2009 08:05 PM
Replacement fence for Porter Cable 698 router table Panzer5 Carpentry 4 04-10-2009 11:47 AM
Porter Cable Plate Joiner 557 for sale JPV123 Contractor Swap 0 02-22-2009 06:30 PM
Porter Cable at Home Depot stp57 Tools & Equipment 30 11-30-2008 01:02 PM
