Portable Table Saw Capable Of 3/4" Dados
Old 07-21-2013, 11:12 PM   #1
Blkhilconst's Avatar
Trade: General
Rewards Points: 75
Well, I was on site yesterday and h/o asked me to repair some old cabinets and doors. I had my saws set up, plus I had my dado blade kit in the truck. I never actually used that kit with my portable saw, the arbor size is good, but the bolt can only handle 1/2" of blades. It's an old Makita, but has served me well. I'm looking for a new portable saw that can handle at least 3/4" of blades. What have you guys come across that work. Thanks in advance...
Blkhilconst is offline
Old 07-21-2013, 11:17 PM   #2
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Re: Portable Table Saw Capable Of 3/4" Dados
Bosch 4100 will do 13/16 IIRC...or better yet, a Router.
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
The Following 3 Users Say Thank You to TBFGhost For This Useful Post:
Blkhilconst (07-21-2013), charimon (07-22-2013), greg24k (07-26-2013)
Old 07-21-2013, 11:35 PM   #3
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,740
If you only do it on a rare occasion, just make two passes. Or, use a router. You can get undersized plywood bits too.
Rustbucket is online now
Old 07-21-2013, 11:47 PM   #4
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
use a router.
m1911 is offline
Old 07-22-2013, 01:13 AM   #5
Trade: General
Rewards Points: 75
I appreciate the idea of using a router, but its time for a new saw anyways. Just wanted more versatility with the new one. Plus a dado on a table saw is almost brainless compared to router and guide. Thanks for the input
Old 07-22-2013, 02:32 AM   #6
steex's Avatar
Trade: repair and remodeling
Rewards Points: 510
This is correct. The smaller Bosch can only take 1/2". The Dewalt 744 will also do 13/16" but I think the little Dewalt 745 won't accept a dado set at all.
You can block all these ridiculous ads in just seconds, for free: www.adblockplus.org
steex is offline
Old 07-22-2013, 04:50 AM   #7
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Send a message via Yahoo to charimon
I have stacked up 3/8" on a 745.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
The Following User Says Thank You to charimon For This Useful Post:
steex (07-22-2013)
Old 07-24-2013, 06:25 PM   #8
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Dewalt 744 will. Not to mention it has the best fence available on a portable saw imho.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 07-24-2013, 06:38 PM   #9
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Lightbulb
You know,....
That's what we need,,,,,a dedicated dado device. A "DDD" - They have hand held planers write?.....I say turn it into a horizontal router "so to speak" load the diamiter bit of the dado you need......clamp a rail on your material and your off and running,,,,,
Mind you they would have to lengthen the wings but it is definitely doable...
That would make the task of running dado's so easy....
B,
PrestigeR&D is offline
Old 07-24-2013, 06:51 PM   #10
Rustbucket's Avatar
Trade: Remodel/Deck
I've seen worm drives converted to run a dado blade. Wouldn't mind having one of those!
The Following User Says Thank You to Rustbucket For This Useful Post:
jkfox624 (07-26-2013)
Old 07-24-2013, 06:55 PM   #11
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,382
I prefer my router on the track saw tracks. But I've had no problems in past days setting up a stacked dado blade on my Bosch saw.
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 07-24-2013, 07:00 PM   #12
Wood Craftsman
Arrow
Seriously.....
It's just a hand planner basically..... so instead of 2" wide knife it's 3/4 23/32.....whatever you need.....but you would be able to set the depth further than 1/8" ....maybe 1/2" .....
I dado on my 88d but its is a pita ...any table saw will be IMO ...fine for long runs but small CC dado ........
Sounds like something Festool should come out with....use it with that rail they have for the circular saw...
As far as The vertical router......ah......to much tear out IMO......I don't like the results . If you could adjust the field plate to the width of the the dado bit (the horizontal idea) you would get very little tear out...I think it would be a pretty clean cut......
B,
Old 07-25-2013, 05:16 PM   #13
Wood Craftsman
Arrow
I love this idea.....
Sucks taking material to a machine to hog out a channel....
I prefer to take the machine to the material....
It's so simple.... if I had a cnc machine and a wealth of programming education...and some engineers hanging around my shop with the a name like Stuart P. Rothchild.......I'd be on it like white on rice......
I love manipulating wood but I think I have an obsession with machinery....
B,
Old 07-25-2013, 08:55 PM   #14
Carpenter/Finisher
john5mt's Avatar
Rewards Points: 1,380
You could do dados with a festool router attached to the track or with a ts55
I wish the dw 745 could bigger dado sets
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Old 07-25-2013, 09:12 PM   #15
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Dewalt 745 (little saw) will only do barely up to 1/4".. basically 2 outside blades of a decent dado set.
If you have to just make multiple passes..
Since getting the 745 dewalt and ts 55 track saw i dont even own a large table saw.. so i have to use a router. I regularly use a 23/32 bit on my router.. but unlike a table saw you have to be very carefull of the router jumping and screwing up the piece.
Downside of a router is if you have multiple pieces it takes to long to set up the guides.
Of course unless you own a festool with guides...
I once had job that required hundreds of 1/4 dados. I borrowed a large table saw for that.
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 07-25-2013, 09:28 PM   #16
Power-Whittler
Clarke Carpentry's Avatar
Trade: Custom Carpentry & Cabinetmaking
A couple years ago I had a brand new Diablo stack spit a couple of teeth at me, one of which stayed in my neck for about 6 weeks. Since then I've converted to doing dadoes with a router.
It's stupid really as I suppose it could happen with any carbide blade but it deffo gave me the fear. Plus now I've got the Festool track set up it's just as quick to do it with the router.
Anyway, the Bosch 4100 is an awesome portable saw, but beware, it's a beast on the gravity rise stand.
I'd go for the little Dewalt for ultimate portability. The little Bosch looks good but somebody on here (Ghost I think) had a lot of problems with it
Clarke Carpentry is offline
Old 07-25-2013, 09:55 PM   #17
Love What You Do !
livingsoulsdie's Avatar
Rewards Points: 150
I had to put 3/4 dados in about 200' of Mahogany 2x4's for railings at one of our job sites. We have a dewalt table saw with the dial. The one without the stand. The arbor was just long enough to hold the blades. That table saw was crying I'm actually surprised that it still works after that job. The top rail had the dado to accept under rail lighting. The top rail is not installed in this pic.
livingsoulsdie is offline
Old 07-26-2013, 01:51 PM   #18
StrongTower's Avatar
Trade: Finish Carpenter
Rewards Points: 1,192
I break out my General International 50-90k for dados and other big projects.
StrongTower is offline
Old 07-26-2013, 02:05 PM   #19
Livin the dream...
Spencer's Avatar
Trade: Remodeling/Finish Carpentry
Rewards Points: 5,398
I hate safety glasses but they are a must on a table saw. Carbides do fly off. A guy I know took one straight to the eye.
You are going to kill the saw if you don't make multiple passes. Take it easy for sure.
I would vote no on the router also. To much opportunity to jack something up.
Lewis Carpentry
Spencer is offline
Old 07-26-2013, 03:34 PM   #20
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 42
I used a Ridgid portable for the 3/4" dados on a bunch of wine racks for a wine distributor. Worked fine.
goneelkn is offline
Portable Cutting table overanalyze Tools & Equipment 69 08-23-2014 05:24 PM
Broke the Tapco cut table out after 3 years. VinylHanger Tools & Equipment 4 05-26-2012 01:00 AM
portable table saw for cabinet making platinumLLC Tools & Equipment 33 05-21-2009 06:39 PM
Looking to Purchase New Portable Table Saw TurnkeyConst Tools & Equipment 22 04-24-2009 11:43 PM
