Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 05-10-2009, 07:28 PM   #1
mdshunk's Avatar
Portable outfeed table....
Anybody got any decent pictures of a home built portable outfeed table, or maybe links to plans or a bought piece? I occasionally need to cut up parts from full pieces of plywood, and it's a pain (and unsafe) to do that by myself. Help out a dumb electrician who's not exactly up to speed on how you guys accomplish this in the field.
(of course I could do it with a Skil saw and a set of horses, but I'm straight line sawing challenged).
mdshunk is offline   Reply With Quote
Old 05-10-2009, 07:33 PM   #2
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
You could get some of those portable Ridgid out feed stands. They work pretty well.
WarnerConstInc. is offline   Reply With Quote
Old 05-10-2009, 07:45 PM   #3
Push it halfway thru, - - let go of it, - - and walk around to the other end and pull it. If 'balance' won't allow it to sit there on it's own, 'fingertip' it into balance from/on the underside as you walk around . . .
Tom R is offline   Reply With Quote
Old 05-10-2009, 07:55 PM   #4
Trade: Finish carpentry
I have a pair of adjustable horses and a 30" x 50" piece of waxed plywood.
The size of the plywood was something I had left over from something years ago. I wax it so there is less drag.
Trim40 is offline   Reply With Quote
Old 05-11-2009, 12:08 AM   #5
Rockler has plans, kits,
and off the shelf.
Fine Woodworking has a bunch,
There was one in the last issue,
or the one previous.
neolitic is online now   Reply With Quote
Old 05-11-2009, 01:34 PM   #6
Trade: Finish Carpentry
The Ridged is the best I have used. I use it on the jobsite for both the miter saw, and the table saw. Because the table of the stand tilts, it allows it to accept sagging wood, then bring it to level. It is the only stand any of the crew uses.
Quiglag is offline   Reply With Quote
Jet Portable Table Saws galla35 Tools & Equipment 5 06-19-2009 01:15 PM
portable table saw for cabinet making platinumLLC Tools & Equipment 33 05-21-2009 05:39 PM
Looking to Purchase New Portable Table Saw TurnkeyConst Tools & Equipment 22 04-24-2009 10:43 PM
