Polyeurathane Glue
Old 09-30-2007, 04:15 PM   #1
MikeNeufeld's Avatar
Trade: Trim Carpenter
Polyeurathane Glue
I seen a guy today build up a 3 peice air inlet manifold for his compressor for finishing and he used polyeurathane glue for all the threads except for the one that threads into the compressor. I thought that was different, any thoughts on this as for how tite the seal would be ass appose to usin teflon tape like normally..
MikeNeufeld is offline
Old 09-30-2007, 09:26 PM   #2
Re: Polyeurathane Glue
any thoughts ... bump for what else you can use for thread locking/sealing
Old 09-30-2007, 09:30 PM   #3
Forry's Avatar
Trade: General Contractor, Remodeler
I'd just use the teflon tape. Works fine, no leaks, and it comes apart again when you need it to. What happens when one of that guys fittings go bad. He has to replace the whole thing.
Edit: Good job spelling polyeurathane. I think. My spell check red flags it when I do it.
Forry is offline
Old 09-30-2007, 09:36 PM   #4
lol... i had no idea how to spell it, but true on the replacement of the fitting, when it leaks or goes, then ur hooped/....
Old 09-30-2007, 09:49 PM   #5
MFWIC
Tmrrptr's Avatar
Trade: house painter
Why not?
It probably won't leak.
r
Tmrrptr is offline
Old 09-30-2007, 10:50 PM   #6
KentWhitten's Avatar
are you talking like gorilla glue? If so, I wouldn't think that it would be a very good type of gasket sealer. I've put that stuff on and it bubbles and foams. And it's not that strong. It's a pain in the rear to take it off carpeting though, and this is from experience. Metal I would think wouldn't take much to break that seal at all.
Salmon Falls Cabinetry
KentWhitten is online now
Old 10-01-2007, 12:18 AM   #7
David Davis
shed-n-deck's Avatar
Trade: ? No thanks, I like mine better!
I would use teflon or pipe dope....I don't like polyurethane for any use.
Shed
shed-n-deck is offline
Laminate Floor Glue Removal EMR General Discussion 8 02-01-2012 01:05 PM
glue on wall Jesse Benson Wallpaper 23 06-15-2009 08:59 AM
No Glue Sheet Floor dayspring Flooring 35 10-02-2008 02:58 PM
Glue on the ceramic tile floor Work is good Flooring 3 07-31-2007 11:40 PM
glue boman47k Wallpaper 7 04-25-2007 12:20 PM
