Point Lasers
I walked into a Hilti center today and looked at their lasers. I was looking at this point laser.
![]() It cost $394.83 I asked him why it cost so much more than the Stanley lasers, he said these are more accurate. Then he looked it up in his catalog and said this laser is accurate to 1/8" in 30'. So I left and looked at this Stanley point laser at Home Depot. ![]() This one cost $199.00 And they advertise the accuracy at 1/4" in 100', which is the same as 1/8" in 50'. That is not less accurate than the Hilti at 1/8" in 30'. I am confused at the differences, is there any reason to pay more for the Hilti one? |
I like Green things
Re: Point Lasers
One Word: Service.
| The Following User Says Thank You to WarnerConstInc. For This Useful Post: | XanadooLTD (08-10-2009) |
Re: Point Lasers
True Hilti offers a warranty, but I don't see how that would affect their lasers. Their warranty only covers use from wear and tear, not abuse, so if you dropped it they wouldn't fix it. And I don't see how you could put wear and tear on a laser, all you ever do with it is let it sit there.
Trade: Log Home Construction/College Student
Re: Point Lasers
Check this out.
![]() Accuracy +/- 1/8 inch at 100' and toolup.com has a special for only $351.00. It includes carrying case, pouch, floor target, and wall bracket. I have the PLS90 and have had no problems with it. |
Trade: Construction
Re: Point Lasers
Whats the advantages of these lasers? I use a auto level rotary one quite often but am wondering what these can do and are they worth a purchase if i allready have a roatary laser?
Re: Point Lasers
They are cheaper, faster to set up, can shoot a 90, and can shoot plumb. They are good mainly for smaller projects, if you're someone who does foundations or excavating all the time, then the rotary laser would be the way to go.
#7 | |
Trade: General contractor
Re: Point LasersQuote:
Bill |
Trade: Trim Carpenter
Re: Point Lasers
plslaser.com
Good lasers( dropped mine a couple of times ) they are accurate to and 1/8" over 100' and are durable. I see Stabila's lasers are so pricey, yet they dont compete spec wise with pls, leica or any others ( dont mean to hijack the thread ) curious as too why this is? |
Trade: Control Systems
Re: Point Lasers
Hilti offers a calibration service for their laser tools.
Stanley can't even make a tape measure, hammer or level properly, why would I ever trust their point laser? |
Re: Point Lasers
At least Hilti understands that they do not make the best laser if they offer this cali service!!!
#11 | |
strat hd
Trade: framing contractor , remodeler , GC occasionally
When snapping lines on a very cut-up foundation this tool came in handy. I would snap lines after pulling paralell's then place the laser at the corners to establish 90 degree angles. Remember this was only used on very cut-up stuff. I would have one guy at each corner of the 90 holding a speed square on the foundation and rotate the laser till it hit both points and adjust accordingly. Sure I can do the math but this method was much quicker. The first few times I tried this I checked lines for square and it was allways on. Works for me. |
Re: Point Lasers
Lasers have been so good for what I do in trim carpentry, railings, columns and cabinatry. Pls LAsers are alway's on the job, never have failures and they are very accurate...
Would recommend over alot of companies... |
strat hd
Re: Point Lasers
Another way I have used it is for laying out ceramic tile in an old house. When the room is'nt parallel or square you can set the laser down and move it around till you find the best layout. In cases like this it's all about reveal at the walls and making it look the best you can.
| The Following User Says Thank You to strathd For This Useful Post: | MikeNeufeld (08-10-2009) |
Re: Point Lasers
I think that extra accuracy with the PLS lasers would be worth the price. But I wonder if they are really telling the truth with their 1/8" to 100'. Maybe Hilti is just honest, so they call it 1/8" in 30'.
I was also thinking of just getting the PMC 36 combilaser: ![]() This one cost $557.24 and is accurate to 1/16" in 30', and shoots lines as well as dots. The lines would be nice, the dots sometimes can be a pain trying to find them. You need one guy with a scrap piece of plywood or something to find it, then a second guy to turn the laser. But with the lines, you could find it easy with one person. |
Re: Point Lasers
go shoot that line from around 30 feet on a pls 180, take a level over to that line and i will garentee u absolute accuracy!!!... Hilti is like mercedes, It looks good, works well and are durable, but you sure pay a helluva alot up front when the lexus does the same trick ( more economically ) imo.
#16 | |
JumboJack for president!
Trade: Hilti walking billboard
Re: Point Lasers
The combi is one bad mama jamma. It shoots the lines from the side to the front. That with the red glasses and you will see perfectly outside even. I guess great for tiling, etc. ALmost like a rotary as you get the 180 degree.
#18 | |
To check it you do what is called a "two peg test". This will work for optical and laser instruments, and is easy to do. Just do a web search for a "two peg test". |
#19 |
Moderator
Re: Point Lasers
I believe Hilti also has a repair price cap. You only pay so much, no more.
Will Stanley even repair a laser?
#20 |
Re: Point Lasers
The two peg test makes sense, interesting. I ordered the PLS5 one, I'm pretty convinced now it's the way to go.
| Crown Point Cabinets | WarnerConstInc. | General Discussion | 10 | 02-25-2011 01:25 AM |
| Newspaper Inserts For Advertising Campaigns | Ed the Roofer | Marketing & Sales | 26 | 02-17-2009 10:20 PM |
| Point load and 2hr Fire Resistance | jjwee | Masonry | 2 | 02-12-2009 09:25 AM |
| anyone hear of FOCUS POINT WINDOWS? | davinci | Windows, Siding and Doors | 6 | 12-06-2008 10:15 AM |
| Please Point The Way: Workers' Comp | Christine | Business | 13 | 11-18-2005 08:03 AM |
