Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 10-28-2008, 03:05 PM   #21
Faking my Way
TBFGhost's Avatar
Trade: Architectural Trim and Punchlist Work
Originally Posted by JBS View Post
My Paslode framing gun will only fire when I go straight in, if I try to toe-nail (using the naural angle design of the gun) I get nothing. No pop, no fan, nothing. Any idea's. The local lumber yard mentioned "brushes", but when I looked at the tune-up book I saw nothing in the exploded parts view for brushes.
Any ideas?
Thanks,
JB
I know this is a little old, but I have the same problem with one of my Paslode Nailer...It is the tip, if I reach up and pull the tip in just a bit further it fires just fine....I think the tip is worn down just enough that it won't fire when the gun in on an angle....
I have both the Framer and 16 angled finish...i love both and would never trade it for the dewalts or any other brand....as far as the framer goes, I am going to see if I can weld a bit of material on the tip and sharpen it up....that should give the length I need to consistently toe nail....and the cold weather thing is not too much of an issue...i just rotate two fuel cells for really cold weather. I keep one in a warm pocket, when the one is the gun gets cold, I swap it out...or if indoors and near a hot water heater...place the cell on top of that.
TBFGhost is offline   Reply With Quote
Old 11-21-2009, 09:44 AM   #22
Trade: carpenter
I have a Paslode finish nailer that doesn't fire. I took it apart and cleaned it and when I put it back together it wouldn't shoot even with fresh fuel. When I trigger it fan runs but there is no spark. It's not dirty, so what's my next step?
Atom is offline   Reply With Quote
Old 11-21-2009, 09:46 AM   #23
LRG WoodCrafting
Leo G's Avatar
Trade: Professional Sawdust Producer
spark plug or spark generator module, is the wire to the spark plug ok?
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline   Reply With Quote
Old 11-21-2009, 09:55 AM   #24
David J Festa Carpentry
festerized's Avatar
Trade: Framing Contractor
try changing the yellow or red gas insert at the back of the gun
Its made of plastic and the housing is alumnium
the softer plastic wears out and gas passes by insert insted of going in gun
festerized is offline   Reply With Quote
Old 11-21-2009, 10:33 AM   #25
Trade: carpenter
Ok, got it figured out. When I took it apart and lubed the o ring as per instructions, the o ring seemed to have expanded so that when I put it back together the o ring would get in a bind and not let the cylinder travel all the way. I fiddled with it a little to get it more evenly seated and then jammed the head down hard enough to force it over the o ring and then it worked just fine. Thanks for the answers; even though I sort of figured it out on my own, I needed this thread to help me do that. Forums are great!
Old 11-21-2009, 10:57 AM   #26
This ain't my first rodeo
loneframer's Avatar
Trade: residential framing/general carpentry
I have had good luck with my Impulse guns. 3 framers, an angled 16 ga. and a straight 16 ga. The only time I have problems with misfiring is in extreme cold or when the gun needs cleaning, which I do maybe thrice a year.
I did have an issue with my straight trimmer with it double firing nails and jamming the drive pin. I pulled the piston and filed the back of the drive pin on a slight bevel so that it wouldn't hang up on the second nail. It has been very reliable ever since.
Operator error can cause the driver to not recoil also. If you "pull back" prematurely during nailing , the piston more often than not will not retrieve far enough back to allow the next nail to follow. Maintaining firm pressure during nailing will virtually eliminate this problem.
loneframer is offline   Reply With Quote
Old 11-21-2009, 01:12 PM   #27
Trade: Construction
These paslode sure can take a beating if looked after. I have dropped 2 of the 3 i have in the lake a few times and a good clean out they work like a dream.
BCConstruction is offline   Reply With Quote
Old 11-21-2009, 01:19 PM   #28
loneframer's Avatar
Just picked up a used/reconditioned 18 gauge Impulse. Complete kit for $199. Aside from a scuff on the case, there isn't even a dirty fingerprint on it.
Old 11-21-2009, 01:40 PM   #29
Trade: Construction
Thats how i bought mine. Recon and it was mint.
Old 11-21-2009, 02:58 PM   #30
tomstruble's Avatar
Trade: siding
Any ideas?
Thanks,
JB
maybe you need to adjust the depth?
tomstruble is offline   Reply With Quote
Old 11-22-2009, 03:47 AM   #31
Scooter
I have been having problems with the batteries backing out just enough to loose contact and I have to give a little push every now and then.
Anyone have an idea for a cure?
The only two things I want to hear.....Wow, you're really expensive! I hope your not to busy.
Chasing Dreams is offline   Reply With Quote
Old 11-22-2009, 06:25 AM   #32
loneframer's Avatar
If the battery isn't backing out to the point of release, try spraying the inside of the battery receiver with a liberal dose of contact cleaner as well as wiping the contacts on the battery itself.
Old 11-23-2009, 11:14 AM   #33
I never see the 18ga. on the ebay/Paslode site. Where did you buy this?
Andrew M. is offline   Reply With Quote
Old 11-23-2009, 11:29 AM   #34
A soft rubber eraser also works to clean batteries and contacts as long as they are not gold plated.
I have a 16ga paslode, older model and I have Hitachi gas framer RH and a 15ga DA type. Both brands work well but the 15ga Hitachi is excellent as long as the fuel is not expired [have issues with a fuel rod only 2 months out of date]and I use only Senco nails. At 4 lbs. and compact size,the battery only nailers are too heavy and large. I had major issues with some old nail strips that have a "T" head instead of the "D" shape of the senco DA. The 18ga from Hitachi is based on the same basic design and is about the same size and price , unlike pneumatic 18ga tools.
Old 11-23-2009, 05:31 PM   #35
loneframer's Avatar
I found it at Home Depot. They had it marked at $225, but they are always willing to mark down the used/remanufactured equipment. I put it to use today, but only ran about two clips through it. No misfires or nail jams, so all seems in order. The belt clip is great and no hose to drag around is pure unadulterated freedom.
The Following User Says Thank You to loneframer For This Useful Post:
Andrew M. (11-24-2009)
Old 11-24-2009, 09:02 PM   #36
Heefs Home Impr's Avatar
paslode brad nails are the culprit...
my 18ga straight brad nailer will jamb with a brad all bent and mangled holding the firing pin from returning for the next shot.
I took it to Paslode in Markham, had it serviced and it ran fine for a day then started all over again.
Frustration sets in when I line up trim,go to shoot a brad and nbothing happens.
So, I ask the service guy about it and he says Paslode has been getting their brads made in , you guessed it, China.
I try porter cable brads also made in China and I have no more issues.
just my experience.
Heefs Home Impr is offline   Reply With Quote
Paslode impulse framing gun problem's tmerring64 Tools & Equipment 15 01-28-2009 08:37 AM
Construction Records Problems PalAl2000 Commercial Construction 5 05-15-2007 06:56 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Solving Problems dayspring Off Topic (Non Trade) 13 06-15-2006 07:45 PM
Paslode Impulse Recondition.. old27 Tools & Equipment 12 06-14-2005 11:11 PM
