Trade: Home Improvement
Paslode Impulse Framing Gun Problem's
I have a paslode impulse framing gun and it is giving me problem's.It fire's ok but the firing pin does not go back .I have to push it back with a screw driver to get it to fire again..I clean the gun regulary and am familiar with it..I just disasembeled the whole thing and cant find out what is wrong. I put it back together and has the same problem. Anyone have this problem? Or can you point me in the right direction?Im in the middle of a job and this blow's.
Trade: Building Contractor
Re: Paslode Impulse Framing Gun Problem's
I had excact same thing happen it turned out to be the firing pin was slightly bent only a fraction but enough to stop it returning to position again! hope this helps?
Trade: Licensed Home Improvement Contractor
Where do you buy your nails? Most nail suppliers fix the guns for the parts cost.
Remodeler
maybe the O ring is worn and needs replacement.
Damned if im gonna do it more than once. |
Trade: general contractor
Just my 2 cents but the firing pin is bent i used to repair nail guns and that was a common problem.
Trade: restoration
I have 4 paslode framers and two angled finishers.
Two of the framing guns will be buried with full honors when (and if) they ever finally quit. One framer is my problem child. In addition to being fixed at least once or twice a year, the pin will jam everytime we load it up with ring shanks. It also uses gas far more then all the others. The last framer only has the pin problem when the operator is not holding it tight to the wood. |
Trade: remoldeling
I'm having the same problem and I know it's my o ring, but I cant find a replacement.anyone know where to look?
Trade: remoldeling
The Deck Guy
I just bought a Hitachi Full Head cordless nailer and I can't believe how well it works. I was afraid it might jam or give me issues like most cordless guns, but this one is a winner.
I also have a Paslode 16 ga angled gun and only experience the driver not rebounding when it's cold out.
Trade: Plumbing & Electrical
Shouldn't need to do this, but you can use some graphite to lube pin/sleeve area. My framer loves his, sometimes it acts up, but a few bad words and a few slaps usually gets it going again!
"....And then we all switch places when I ring the bell" -Adrock
LC Australia
Trade: Building
Honestly, Paslode framing gun gives me so many problems, it's crap. I went back to the pneumatic gun. Half the time it didn't shoot, and half the time the it didn't shoot again.
"It's better to die on your feet than to live on your knees" |
Dan
i use both kinds, air and the paslode and they each have their places. sometimes hoses are a pain to deal with.
anyways, i don't think it's the oring in his case. the o ring probably usually is when the safety tip that you push against the wood won't retract back out, he's talking about the actual pin that slides in and out that channel from the firing cylinder. i've had mine for 7 years now and it works great. i replace the o ring about once a year and clean it like every other box full of nails. (sometimes longer) i do know the frustrations though of when you want it to shoot just one nail to hold something up, it wont' fire. i know the coil hitachi air gun always fires. and faster too. good luck with the gun, any lumber yard that sells tools should have the paslode parts in stock if they are a good yard. homodepot doesn't stock parts or fix the crap they sell, so i find myself going to the mom and pop places to buy stuff because i know i get treated better if/when i need service etc. it's not worth saving like 20 bucks at the big box stores just to screwed when it's time for service. morons at HD barely know how to tie their shoes before going to work, let alone order parts for a paslode gun. i wish they sold the positive placement nails there though! that's the best gun paslode ever invented! |
We have Paslode finish and framers...no problemo(s).....We keep them cleaned up good and have never had any problems...even framing in 10 degree weather.... (love our Paslodes)
(FWIW: We still use compressors and hoses for larger frames and finish projects)
- Build Well - |
#14 | |
Hi, i wanted to post a reply on the paslode extreme working conditions... We work in Quebec with paslode 350 pneumatic framing guns and others staplers at -35 and that is their OFFICIAL minimum because all the plastic parts explode on the inside when you nail below -35
![]() Just though i leave this comment ![]() Johnny Cool, Montreal, Canada Quote:
Air Tools
Trade: Professional Supplier
I have repaired Impulse tools since the first Black IM300 tools came out in 1987. I can tell you that the driver pins very rarely bend. It is not to say that the don't but it is very uncommon. The main reason for the driver not returning is usually the oring in the mid check area of the tool. Not the oring on the head of the tool by the fan but the oring that is on the sleeve. Replace this oring Paslode item# 404482 and that should do the trick.
Best, Mark |
| The Following 2 Users Say Thank You to bcfast For This Useful Post: | BCConstruction (03-26-2011), TBFGhost (11-07-2010) |
Trade: siding
Mark right the broken o ring rolls out of the groove and jams up not allowing the driver to retract all the way
| The Following User Says Thank You to Tom Struble For This Useful Post: | TBFGhost (11-07-2010) |
Trade: Home builder
The problem is the o ring. I find that it is usually the smaller o ring by fan, I buy these buy the gross and must replace about every other cleaning. The problem you are having is that the o ring has either broke in two or has a chip in it and thus after firing there is no compression to suck the piston back up into firing position for next shot. I have found that the bigest cause of this is that employees get frusterated with gun when it will not fire and does not seem to let safty depress all the way and they pound the point on the sub floor, unfortunetly this sometimes works because it realigns the o ring allowing it to slide back into position, but must of the time it either breaks a piece of o ring off or mis shapes it and once this happens they o ring is usless. The guns are actually very simply I clean mine about once every box or two of nails and then once a year I do a thourough cleaning where I break gun down to single components and clean them all.
Good luck |
#18 |
Project Manager/Carpenter
Trade: Carpentry/Reno
a dead post brought back up twice...lol
#19 |
Trade: siding
Re: Paslode Impulse Framing Gun Problem's dam i fall for it everytime
Tom |
#20 |
Trade: carpentry, remodeling
Weird thing is I had the firing pin on my Paslode BREAK not once but twice. So, I guess I'm changing the o ring out at the midcheck. I'm guessing you guys are talking about the big rubber o-ring at the bottom of the chamber? But still can
t figure out how the gun is shooting two nails at once? Anybody? Again, thanks. guys. |
| Paslode Impulse Problems | PLC-Landscape | Tools & Equipment | 49 | 07-27-2010 09:03 PM |
| Window header 2x6 framing | Atlantex | Framing | 20 | 11-06-2007 10:55 PM |
| Common Patio Door Problems | adriand | Remodeling | 1 | 01-14-2007 01:27 AM |
| Problems with new Bostich framing nailer-new style | IHI | Tools & Equipment | 6 | 09-20-2006 12:14 AM |
