Paslode Gun Want Fire
Old 09-07-2007, 01:00 AM   #1
watchman05's Avatar
Trade: framer
can someone tell me why my gun want fire i clean it new battery and gas help or wher i can get it fixed.i live in tenn. kingsport
watchman05 is offline
Old 09-07-2007, 05:37 PM   #2
Mod / ArchiBuilder
Cole's Avatar
Re: Paslode Gun Want Fire
It could be anything.
Have you taken it apart and see if you have visible problems that you can fix?
Cole is offline
Old 09-08-2007, 02:57 PM   #3
troubleseeker's Avatar
Check out the numerous posts over time about these guns. If you are sure it is clean and has a good battery, check the expiration date on the fuel cylinder. Just because you just purchased or installed it does not mean it has not lost pressure. If it is none of the above, sounds like a trip to the service center, there is an internal contact switch that can fail, and when it does, the gun will do absolutely nothing.
troubleseeker is offline
Old 09-08-2007, 03:10 PM   #4
If you are sure it is clean and the battery is good, check the expiration date on the fuel cylinder. Just because you recently purchased or installed it does not mean that it has not lost pressure. If none of these, sounds like a trip to the repair center is in order. There is an internal contact switch that can go bad, and will result in the gun doing absoloutely nothing. If the fan runs, it is not this switch, so I would suspect old fuel, a cylinder not properly seated in the little "V" notch in the gun. or a bad rack of nails. If the rack is too bent or the collation tape is swollen it can stop the nails from advancing fully to the firing position and will engage the anti dry fire mechanism.
Old 09-14-2007, 01:43 AM   #5
watchman05's Avatar
Trade: framer
thanks eveyone for your help I checked every thing time to go to te service center thanks
Paslode Impulse Problems PLC-Landscape Tools & Equipment 49 07-27-2010 09:03 PM
Concrete fire pit ronald owen jr Masonry 14 08-07-2007 10:24 PM
Fire Place Miller Painting & Finish Work 15 04-21-2007 07:37 AM
fire box construction ELM Masonry 8 02-01-2007 01:08 PM
fire door mechanism 72chevy4x4 Electrical 4 01-11-2007 09:38 AM
