Paslode Framer Problem
Old 07-29-2008, 07:04 PM   #1
sqrl's Avatar
Trade: residential
grrr,
I'm in the middle of framing up an addition, my paslode framer cycles but won't fire the nail. I smell the gas and hear the fan but... nothing. I took it apart and cleaned it. And it worked for a few minutes. It's almost like if I could figure out how to giggle the trigger it would fire. What is happening and why??? can I fix it myself? The clock is ticking. I've got two hundred dollars worth of nails for this gun.
Thanks,
sqrl
sqrl is offline
Old 07-29-2008, 07:10 PM   #2
Steve
OCRS's Avatar
Re: Paslode Framer Problem
Service warranty?
OCRS is offline
Old 07-29-2008, 07:22 PM   #3
Dan_Watson's Avatar
IS the firing pin stuck out?
Dan_Watson is offline
Old 07-29-2008, 07:37 PM   #4
Tom R's Avatar
Are the nails from home depot?? Try a different clip.
Tom R is offline
Old 07-30-2008, 02:17 PM   #5
Jthebuilder's Avatar
Trade: home contractor,and home repairs
when framing use air
Jthebuilder is offline
Old 07-30-2008, 04:07 PM   #6
I like Green things
WarnerConstInc.'s Avatar
yes get out the compressor.
WarnerConstInc. is online now
Old 07-30-2008, 04:21 PM   #7
Tom R's Avatar
No shortage of air-heads around here . . .
Tom R is offline
Old 07-30-2008, 04:24 PM   #8
Dan_Watson's Avatar
Air on bigger frames, maybe have the paslode out for certain things, but usually the paslode is for remodels where there are just a few nailers, or a small wall.
Old 07-30-2008, 06:50 PM   #9
bob14-0's Avatar
Trade: home construction
Did you check the date on the fuel cell? No one mentioned this yet but it's the most common solution to erratic firing problems with the Paslode cordless guns. If the fuel is fresh and it continues to operate poorly, a complete overhaul should fix the problem.
Regards, Bob
bob14-0 is offline
Old 08-03-2008, 02:57 PM   #10
Philly Dude's Avatar
Could just be out of fuel too. When the can is low it will fire sometimes and not fire others. (Yes I learned this the hard way)
Philly Dude is offline
Old 08-03-2008, 03:03 PM   #11
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
I have said it before, and I will say it again. All battery operated what have yous is good for the punch list guy, or the weekend warrior. If you use it on a big job you will have problems. They are not designed for use like that.
got air?
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 08-03-2008, 04:27 PM   #12
I remember hammers
G&J's Avatar
Trade: General Contractor, residential/light commercial
got air?
I'm a big fan of battery power, I run two Dewalts and one Passlode ( I prefer the Dewalt 628 )but USP45 is right for big jobs my recommendation - run the airline. For trim I loves ma battery guns.
G&J is offline
Old 08-03-2008, 11:14 PM   #13
Aiken Colon's Avatar
Trade: Construction Supplier
Anyone ever tried the Bosch Bammer? We use to have it a few years ago and always seemed to get good reviews on it.
JJ
Aiken Colon is offline
Paslode Nailer SAS Introductions 4 01-20-2008 07:04 PM
Electrical Problem abonear Electrical 73 02-10-2007 02:04 AM
interesting problem! thunder7 Plumbing 7 02-04-2006 10:26 PM
Washing Machine/Floor Vibration Problem NHCharger General Discussion 13 01-18-2006 07:52 PM
Electrical problem? Brian Electrical 5 12-27-2005 11:16 AM
