HRUBY
Guest
Posts: n/a
Paslode F350 Major Air Leak
When I attach the air hose from compressor to the Paslode f350 the air comes directly out the air deflector port. Any thoughts about what may cause this?
Thanks
mdshunk
Guest
Posts: n/a
Re: Paslode F350 Major Air Leak
Yes, pretty common failure for any air nailer. Nothing the seal kit won't fix up.
http://www.bcfast.com/paf3rekit.html |
HRUBY
Guest
Posts: n/a
Thanks for the advice, tried to pull the back housing off, any experience with that. I don't want to pry too hard on the cast aluminum.
mdshunk
Guest
Posts: n/a
Just order the kit. It's like 20 bucks, and comes with a comic book that shows you how to do it. You're gonna fool around and F up a good nailer.
HRUBY
Guest
Posts: n/a
The kit is on the way. I got the back off, found a dried up, brittle plastic seal on the end of the cylinder. Your right, I don't want to
it up.Thanks for the time! |
| leak in pex | go do it | Plumbing | 28 | 12-11-2011 03:40 PM |
| Paslode 16 gauge Straight Finish Nailer For Sale | JPV123 | Contractor Swap | 0 | 02-22-2009 06:56 PM |
| leak under sunroom exterior wall on slab | jrcuts | Framing | 7 | 01-09-2009 06:17 PM |
| Pex tube leak under cement floor | jonbjornstad | Plumbing | 22 | 12-23-2008 09:44 PM |
| water leak detectors | threaderman | Plumbing | 7 | 04-16-2008 07:00 AM |
