Paslode Cordless Nailer
Old 03-16-2008, 04:52 PM   #1
NRV2's Avatar
I have both the angle finish, and the fraiming nailer. They both are fussy about when they will work or not. Its like I have to hold the gun at just the perfect angle or it wont work. Does anyone elso have this problem with the Paslode?
NRV2 is offline
Old 03-25-2008, 09:54 PM   #2
bob14-0's Avatar
Trade: home construction
Re: Paslode Cordless Nailer
I've had my Paslode framing nailer for years and it works great most of the time. If the safety contact isn't engaged just right it won't fire; if the gas cartridge is old is won't fire good but generally it's dependable. Make sure to clean if it really lets you down.
You must have a pneumatic nailer primarily, butane-fired for back up and small jobs.
Regards, Bob
bob14-0 is offline
Old 03-25-2008, 10:02 PM   #3
p1grinder's Avatar
Trade: flooring
with the new co2 tanks i dont see the point in getting a cordless nailer. get the co2 tank and all your nail guns are cordless.
p1grinder is offline
Old 03-25-2008, 10:25 PM   #4
Feedin the geese
Joining_heads's Avatar
Trade: Finish Carpenter
Welcome to the world of gas nailers. Sorry, I've always had the same experience. My 1st employer bought 2 or 3 of each (finish and frame). They were in the shop all the time.
Joining_heads is offline
Old 03-26-2008, 08:36 AM   #5
bob14-0's Avatar
That's something to consider - what's the cost of the tanks, can they handle a framing gun?
bob14-0 is offline
Old 03-26-2008, 08:12 PM   #6
valleyman's Avatar
Trade: Kitchen and Bath remodeling
I don't think any of them can handle a framing gun.
As you know, CO2 becomes very cold when discharged rapidly.
I've heard talk of people's guns freezing up, but I've never used the system.
Lowes sells the kit for around $80. Then it's cheaper to go to a paint ball game shop to get your tank refilled. I'm really thinking about trying this for finish nailers. You can keep your light, compact and reliable guns and be practically cordless.
valleyman is offline
Old 03-26-2008, 08:27 PM   #7
1018's Avatar
We've got a Paslode framer at work for quick re-framing (100 year old building, rotted wood just about everywhere) and it's worked fine through the cold, snow, and heat. Just make sure you clean it after each day.
1018 is offline
Old 03-26-2008, 09:20 PM   #8
Quiglag's Avatar
Trade: Finish Carpentry
Send a message via AIM to Quiglag
I haven't used one in at least a year, but I do remember having problems with it. It was the finish nailer, and It seemed like it was a waste of time to even try to get it to work.
I just ended up buying the smallest Senco air compressor. It works great for room to room type stuff.
Quiglag is offline
Old 03-26-2008, 09:31 PM   #9
odellconstruct's Avatar
Trade: carpenrty, remodeling , residential
make sure its clean , and a fresh battery , and know hen the last time you changed the fuel cell you shouldt have a problem , you wouldnt just get in and drive a car til it stops would you ? preventative maitnence
odellconstruct is offline
Old 03-26-2008, 09:36 PM   #10
AtlanticWBConst's Avatar
Are these new guns? Are they re-maufactured? Are they used?
Parts can get damaged, or worn out, etc.
Had a problem with one of our paslode angled finish nailers.
Took it apart to clean it, and found 1 broken part, and two bent parts.
- Build Well -
AtlanticWBConst is offline
Old 03-26-2008, 09:53 PM   #11
mikegp1's Avatar
Trade: Renovations
I also found if the gas cartridge is cold it wont fire correctly. I keep my in the trailer all the time and if its cold i just warm the cartrige in my hands for a few and it works great.
mikegp1 is offline
Old 03-26-2008, 09:59 PM   #12
p1grinder's Avatar
Trade: flooring
i've never had a problem with freezing up but when i know i'm gonna fire a lot of nails i grab the compressor and just a fun fact co2 turns to a liquid when compressed so a lot of air in that lil tank.
Old 03-26-2008, 10:44 PM   #13
bob14-0's Avatar
Just used my Paslode cordless framer a few hrs ago on a Habitat basement project. I only needed a few 8's to attach a small cleat above a window header for installing blinds. Sure was convenient to throw the gun in the trunk this morning for a small job after work.
I hadn't used it since last fall and it performed flawlessly tonight.
Lovin the Paslode.
Bob
bob14-0 is offline
Old 03-26-2008, 11:30 PM   #14
al10fred1081's Avatar
Trade: Carpentry/ Home Improvements
If you have the depth of drive adjustment all the way back to TRY to countersink the nail... take a look at the nose on the gun and you will notice that it sticks out further than the safety when you are trying to toe in nails. I resloved this by taking the grinder to the front of the gun and now it toes in with no problems. I took about 3/16ths off mine, but you could probably hand file it to be perfect. I just knocked mine back because I was toeing in nails all day and needed a quick fix. check it out and see if the gun works when the depth of drive adjustment is set forward. then take a look at how far the nose sticks out when the DOD adjustment is all the way back. Mine works fine now and I even got to the point where I could quit throwing it across the yard when it failed to fire.
Alex
al10fred1081 is offline
Old 03-28-2008, 08:45 PM   #15
NRV2's Avatar
My guns were bought new. I have used them maybe 15 hrs each. Talk about when its cold, I can't even think about using them when its below 20*.
I really like how easy and portable they are, but they can be a hasle
NRV2 is offline
Old 05-27-2011, 12:31 PM   #16
MKPR5's Avatar
The primary reason I have ever had an issue like this was because the gas cartridge was old or the carburetor cap on the cartridge was bad. Check the date in the cartridge and replace if old. You can also test the carburetor by removing it from the gun and pressing the nozzle against a block of wood. When you pump it about five times in a row you should get a consistent spray from the nozzle each time. If you don't, try putting another carb on the cartridge and do it again to see if it's the carb or the cartridge that's bad. Remember to use the same carb from the same type of cartridge since they deliver different amounts of gas.
Just realized this is an old post.
MKPR5 is offline
Old 05-27-2011, 02:16 PM   #17
Brad 1's Avatar
Trade: Remodeling, framing, trimming, etc.
They should not do that. Something is possibly bent or broken if that's the only way you can get them to fire. When you push down on the safety it activates a micro switch that starts the fan. The fact that both a finish and framer do it is odd though since they are fairly different from each other parts wise. I would start by disassembling and fully cleaning them. Replace the filter and sealing o-ring, (some use metal rings, like what is on the piston, instead of the rubber o-ring) inspect the other parts for any damage, replace any bad parts, lubricate it and you should be fine.
Brad 1 is offline
Old 05-27-2011, 03:42 PM   #18
GettingBy's Avatar
A single 12 g. CO2 cartridge stores 650 ft-lbs, 0.24 watt-hours, of energy, so it may or may not be cheaper than batteries in the long run.
If you discharged the whole cartridge in one second you could get 1.2 hp, 900 w.
GettingBy is offline
Any Paslode Framing nailer owners? dkillianjr Tools & Equipment 16 03-08-2008 12:24 PM
Anybody ever use cordless guns besides paslode or dewalt? al10fred1081 Carpentry 7 03-01-2008 12:38 AM
anybody ever use cordless nailers besides dewalt or paslode? senco? hitachi? al10fred1081 Tools & Equipment 0 02-24-2008 11:28 PM
Paslode Nailer SAS Introductions 4 01-20-2008 07:04 PM
My first Paslode Cordless guns Deacon Tools & Equipment 12 02-01-2006 08:37 AM
