One Of The Best Tools
Old 01-04-2006, 11:09 PM   #1
Teetorbilt's Avatar
I'm suprised that I have never mentioned this gem, I have spent more hours with it than any other tool. FYI, this goes back to the 'best transition' subject that I posted. To pretty much complete that job, this is what you need.
Albert Einstein
Teetorbilt is offline
Old 01-05-2006, 12:40 AM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: One Of The Best Tools
If you are talking about using it as a grinder instead of polishing you boat, I would agree. I reach for this tool quite a bit during a remodel.
Mike Finley is offline
Old 01-05-2006, 07:18 PM   #3
The Deck Guy
Greg Di's Avatar
Angle grinder I can see, but a polisher/buffer?
The angle grinder is one of those tools you need when you need and it definitely will save your skin in a pinch. It's definitely for rough work only.
I think what is more important to always have in the truck is Fein Multimaster. You can cut in the most impossible places with that thing--surgically.
Greg Di is offline
Old 01-05-2006, 07:36 PM   #4
Teetorbilt's Avatar
This model is one of the toughest tools ever built. I used them when building hydrofoils out of fiberglass, and later, cast and laminated epoxies. The workforce was not always topnotch and I had ONE gear failure in 12 yrs.
We used 8" softpads, 60 grit and worked to +/- .002 in. I have used it on mold plugs to .0005in.
I would not recommend it as a grinder with hard disks as for metal work but it can work wonders for anything less than that.
Albert Einstein
Old 01-05-2006, 09:27 PM   #5
Dripless
Dale's Avatar
Trade: Painting and exterior wood care
Thats my favorite tool for defelting decks after being restored. The 9227C has been bulletproof for me, the only thing I've had to do is clean the trigger lock a couple of times because the sawdust builds up and locking and unlocking is difficult. The variable speed is a nice feature.
Dale is offline
Old 01-05-2006, 10:57 PM   #6
General Contractor
nadonailer's Avatar
Angle grinders are the tool I would take to a desert island if I could only take one!
"History does not long entrust the care of freedom to the weak or the timid”.
Dwight D. Eisenhower
nadonailer is offline
Old 01-05-2006, 11:22 PM   #7
I'm just stirring the:
CGofMP's Avatar
Trade: .
Had never seen the Fein tool before.. looked it up online and it looks pretty sweet. Lots of places I could use this one.
I only wish it was not 300bucks
Memorable Places - My little home on the web
Member of the White Knights Of Contractor Talk
CGofMP is offline
Old 01-06-2006, 08:03 PM   #8
The Deck Guy
Greg Di's Avatar
It's the best $300 you will ever spend on a tool. The reason it's expensive is because it's built really well--better than any Dewalt, Bosch, Hitachi tool--plus it comes with a bunch of accessories that are very expensive.
An E-cut blade is about $50, but it will make a cut you can't get with anything else.
Greg Di is offline
Old 01-06-2006, 10:28 PM   #9
Teetorbilt's Avatar
CG, check this out. http://www.acehardware.com/product/i...ductId=1831322 I just saved you over $100 and your getting a bulletproof tool. The original post was a Makita and I swear by them.
Add this pad http://www.sjdiscounttools.com/dis8056.html and you're ready for some serious work.
You can roughout compound curves in a heartbeat, fair in boards and ,with the bonnets, compound and wax your boat. Notice how shiney mine is (not). If the weather is good enough to wash and wax, it's good enough to fish!
The genset is in the cockpit because the O-Nonan bit the dust 3 days prior to the trip to the Bahamas and there was no time for repair or replacement. A new 4.0 Westerbeke now sits in it's place. We were not 'good neighbors' with a construction generator running in the cockpit but we were cool.
Albert Einstein
Tools For Sales At Low Prices man6_27260 Contractor Swap 1 06-30-2008 10:58 AM
Sheetrock Finishing Tools!!! Mud Master Drywall 19 02-29-2008 06:58 AM
Opinions on the best tools for Pex Dragonheart Plumbing 1 07-06-2007 04:16 PM
Relocating Tools: job to job WNYcarpenter Finish Carpentry 36 04-04-2007 08:10 PM
Harbor Freight tools or Name Brand? GridRunnerFloor Flooring 18 06-09-2006 10:19 PM
