Trade: Home Restoration Services
Old Stanley Hinge Mortise Kit
Hey Guys...New to the forum, Hello!
In my business I dont do much in the way of door replacements and when I do it is usually prehung units, But being sort of an old tool snob I couldnt pass up this smokin deal on an old stanley "builders kit" which included the hinge mortise kit. This is very similar to the bosch unit sold today, but Im unsure how to use it exactly. Wondering if any of the guys on here have ever used one. (Its pretty old, think EARLY 50's) Let me know...Id love to hear your thought! |
Re: Old Stanley Hinge Mortise Kit
if it is like the bosch there are two rods and 3 jigs and 1or2 top spacers
Im recalling this from memory so if any thing is off in my post help me out on the side of the jigs are a series of holes with a pin these are for the hinge size in the middle of the jig is a threaded knob on a lever this is for door thickness centerd is for 1 3/8' doors. the larger door sizes you flip the knob from the door to the jamb (you should play with the jig a few times to get the hang of it) one of the three jigs has a cutoff end this one is for the top spacer there are numbers on the top spacer and this is for the number of inches down to the first hinge. the movible flat part of the spacer is so you have proper space between the door and top sill bend it down for more gap up for less but you have to make sure you bend it properly so it is consistant for both right and left hand doors the "rods" have numbers and holes these give spacing for the hinges based on the topspacer choice and (hinge size ?) and door length. hope this helps Craig |
| The Following User Says Thank You to charimon For This Useful Post: | jtequipment (02-12-2010) |
charimon thanks for the help. I dodnt get on much but looked at your post and the instructions on bosch website. they are close but not quite it. Ill just have to play around on some old doors and see if I cant do some damage! thanks!
| Stanley hinge template | Pakfan | Finish Carpentry | 14 | 04-01-2010 07:45 AM |
| Jig for positioning / drilling euro style hinge recess | Bonzai | Tools & Equipment | 6 | 01-09-2010 09:11 AM |
| Hinge help | Jeremy E | Finish Carpentry | 23 | 12-15-2009 06:16 AM |
| door mortise drill bit | debbymoge | General Discussion | 10 | 07-16-2009 10:15 PM |
| Stanley Fatmax Lasers | Buca1025 | Tools & Equipment | 5 | 02-01-2009 10:05 PM |
