Palisade Point Const.
Old Beam Saw? (56k Warning)
I've found this old beam saw at a second hand shop-
![]() ![]() it's a Mall Saw model 120. It appears to be worm drive, and spins a 12" blade. ![]() ![]() I'd be interested in refurbishing it, but I can't get any information on it. I'm particularly interested in how to find blades for it, because the arbor looks like this: ![]() the square is roughly 3/4" on a side. Also, has anyone ever seen a saw that plugs into a light socket before? ![]() Anyways, I'd be interested if anyone has any information on this saw. |
Re: Old Beam Saw? (56k Warning)
All you need to know:
http://www.google.com/patents?id=0Jx...BAJ&dq=1623290 |
This is the first thing I found...
http://www.smokstak.com/forum/showthread.php?t=21705 I knew I had seen the name before, and it must be 'cause the sold through Monkey Ward. ![]() The screw socket deal is maybe a user modification, I remember seeing cord-ends like that in hardware stores. Keep Googleing with the company name, md has posted from some patent search data bases in the past.
nice post, thanx
#5 | |
Re: Old Beam Saw? (56k Warning)Quote:
I've searched around for Mall Saw, but I can't get any information on the model 120. I can find information on the mall chainsaws and the model 71 corded saw, which is a smaller, less powerful sidewinder. |
Oh, almost forgot. That connector that screws into an Edison based socket; that's called a "Benjamin Plug". It was the standard tool connector used by the railroads once upon a time. It may well have come on the tool that way if the railroad originally purchased this saw for their use.
EDIT: Here's that plug, from a 1936 Westinghouse catalog. The bottom one looks like the one on your saw:
they must have made a few different size saws, if you note on your 1st and 3rd photo, the mallsaw id plate on the gaurd is made for a different diameter saw, it does not follow the radius of the gaurd.
Not long ago I scrapped out an old
extension cord with a female socket end, so maybe that's what the guy was doing there too. I imagine you could change it to a blade end. It probably came that way. Keep searching, it'll keep you off the streets and outta th' pool halls!
the store thats selling it doesn't know anything about it either- the tag on it lists it as a "big a$$ saw".
Re: Old Beam Saw? (56k Warning) |
#11 | |
Thanks for that "Benjamin" thing, I knew that once. ![]() I used that old cord as a work light til the rubber disintegrated.
He certainly was on the cutting edge!
i read thaT you indeed bought this saw... let me know if you ever want to sell it.. i have two allready and we actually use them regularly. if so please email skulybros@aol.com thanks for your time!
Trade: Squirrel Handler
Cool! Does anyone still have a 56k modem?
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
#18 |
Probably the guy that still uses those saws
#19 |
Trade: sparky
I would almost bet that MDshunk has a few of those around his area. Amish carpenters building post and beam construction use saws like that although that one is a bit on the small size compared to the last one I saw being used. I think that one had an 18 inch blade.
and I didn;t see anybody address the hole inthe blade;unless that saw has a really odd arbor, you use an insert of the correct size for the arbor. That way one blade and a few inserts can fit any size arbors. |
#20 |
you have to have a modern blade stamped to fit the arbor.. i that is what I do.
quote=nap;458031]I would almost bet that MDshunk has a few of those around his area. Amish carpenters building post and beam construction use saws like that although that one is a bit on the small size compared to the last one I saw being used. I think that one had an 18 inch blade. and I didn;t see anybody address the hole inthe blade;unless that saw has a really odd arbor, you use an insert of the correct size for the arbor. That way one blade and a few inserts can fit any size arbors.[/quote] |
| rotten beam replacement | Slumlord | Framing | 5 | 05-11-2008 10:12 PM |
| I Beam ....or another alternative | bkcm111 | General Discussion | 9 | 03-14-2008 05:33 PM |
| Steel beam replacement | BHI | Carpentry | 17 | 02-28-2008 12:03 AM |
| need some advice framing to a beam | Vabuilder | Framing | 23 | 02-22-2008 04:41 PM |
| Updating main beam in century-home: end. | bob_cntrctr | Framing | 8 | 02-07-2008 04:04 PM |
