#21 |
Trade: carpenter/ handyman
Re: Nicad Battery Fix Repair Guide?
The guy that I purchased my guide from (over a year ago) has set his site up so that it can't be forwarded. All power to him if he wants to make a buck.
The technic is pretty simple. You must have a digital voltmeter. Jump your 14.4 v battery with a 18v battery (fully charged) for only 5-6 seconds at a time. Check the voltage after every 6 second jolt. When your battery reaches at least 16 volts then you can place it on the charger. If it won't get past 14.4 volts then you have a bad cell. All of the cells are 1.2volts & can be purchased online & soldiered in place of the bad cell. Note: Make sure that you match the polarities correctly when jumping the batteries. If you are resurrecting a 18v batteries then you can jump it with (2) 12v car batteries in series or (4) 6v lantern batteries. Steve |
#22 |
I have never tried this with a car battery. The repair guide I used required at least one good tool battery to perform the fix. Most people have at least one sitting around I would think.
The idea is to "burst" the hairs or crystals that build up in the cell. This done by jolting the bad battery with a quick shock of usually double the volts of the battery your repairing. Its easy, but the steps need to be done correctly! Click here ----> linkremoved Last edited by Nathan; 04-23-2009 at 03:23 PM. |
#23 |
Trade: Professional
Here are the instructions for fixing nicd battery!
If it doesn't work, not my fault! Blame the creator @ above post! |
#24 |
Trade: Remodeling, General Construction
Re: Nicad Battery Fix Repair Guide? |
#25 |
Trade: High Pressure Air
My question is has anyone found a good way of reconnecting batteries in a cell that were connected using metal strips spot welded to the ends of the batteries? I have tried to solder in a good replacement cell and cant get anything to stick.
RE the shock method I had learned a simular method for reviving large lead acid gell cells with dead cells several years ago. If I recall for the lead acid you put about twice the normal volts on it from a power supply that had a current limiter. The voltage was high but once the bridging had burned thru the current limmiter kept the powersupply from destroying the battery. |
#26 |
maninthesea,
I've wondered the same thing but I can't seem to get an answer anywhere. Steve |
#27 |
Trade: Carpentry/Contracting
tried truck starter on 200 amps .... no dice, i thought it would at least give me 12 volts
#28 |
Trade: general construction, home builder
hello, all the info you give is awesome. I was wondering about the link to the battery fix instructions. The link to the pay web site is there but in the next post you type in here is the instructions and there is nothing to click on.
#29 |
Trade: electrician
very cool info... had no idea this was out there!
thanks all |
#30 |
checkin
Can you use a dc power supply, or a auto battery charger?
Trying to jumpstart dead 7.2 battery pack. |
#31 | |
Re: Nicad Battery Fix Repair Guide?Quote:
Steve |
#32 |
Trade: bulider
what volts should u see when u do a ryobi or makita 18v battery
thank u |
#33 |
24 volts works great. You can either use two car batteries in series or 4 lantern batteries (6V) in series. I use the lantern batteries.
Steve |
#34 |
Trade: Custom Metal Fabrication/Residential Construction
Sounds great for Nicads but does the same fix work on lithium batteries?
#35 |
does any body have step by step instructions how to do it..?
i got a few dead batteries laying around!
The Bitterness of Poor Quality Remains longer Than The Sweetness Of A Low Price Is Forgotten
#36 |
Trade: General Contractor - Residential
Do a google search for "ysuusy" "easebatteryfix" to find the instructions
#37 |
#38 |
Steve
Trade: Remodeling and Custom Cabinets
I used 2 18V Dewalt batteries in series to give me the shock power of 39V.
I fixed 3 today, very nice tip. My Fluke meter leads slipped over the battery connections so I did not even have to create a jumper wire, I just used one lead between NEG on 1 battery and POS on the other. Money Stays in the Bank ![]()
#39 |
Trade: cabinetry
Before "surge-jumping" your battery pack with extra volts you might want to try the following technique (it worked for me):
1. Try charging your battery overnight 2. Remove the battery from the charger 3. Now momentarily short the + and - terminals of the battery The shorting could be done using a short piece of wire - or - use a paper clip that you have unbent. When you short the battery there will be a healthy spark. Please use caution, goggles and gloves would be a good idea, and make sure you short the terminals for only one VERY brief moment. NiCads can generate quite a bit of current and this jolt can sometimes be sufficient to revive any weak cells. If this simple shorting tecnique does not work you can try the SURGE METHOD outlined at: ysuusy . com / easybatteryfix . html . Last edited by John Netbee; 09-06-2009 at 11:31 AM. |
| The Following User Says Thank You to John Netbee For This Useful Post: | kavasports (12-16-2009) |
#40 |
Trade: Railing
For those having trouble soldering, It takes a lot of heat. You need a soldering iron with a big enough tip, 60/40 rosin core, or solid solder, along with a little pase flux. Radio Shack is a great place for these. For detailed instructions, I'd go to an Radio control site, & go to the faq section for the nuances. Try Radio Control Car Action (RCCA) for help.
Joe |
| estimating guide for windows? | Grumpy | Windows, Siding and Doors | 20 | 11-26-2010 08:18 PM |
| Foundation repair (New business) Help! | crosshair66 | Business | 10 | 05-18-2008 09:19 AM |
| Free Download: Advanced Energy Design Guide | Ed the Roofer | Roofing | 0 | 02-09-2008 09:01 PM |
| Website and keywords | tinner666 | Marketing & Sales | 10 | 12-31-2007 08:10 AM |
| Chicago Home Repair License? | Grumpy | Contractor Licensing | 24 | 09-15-2006 12:48 AM |
