Need Help With A Core Drill
Old 04-16-2009, 10:19 PM   #1
What goes in this space?
FJRFencer's Avatar
Trade: Fence installations
I have a milwaukee 20 amp on a stand. My 4 inch bit just refuses to come off. I have let the thing soak for days with PB blaster and wd 40.
applied heat with a propane (plumber) torch (all I have)
Used a 6 foot cheater bar and 2 guys to help hold it in place,
broken the OEM removal wrench that came with the drill.
I guess My drill will only do 4 inch holes now.
any great ideas out there?
Yes, I used the copper washer with it to (supposedly) prevent this from happening
http://www.jandkfencing.com
FJRFencer is offline
Old 04-16-2009, 11:50 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Need Help With A Core Drill
Get it hung up in reverse...
Usually works believe it or not, I'm not being smart
Chris
Chris Johnson is online now
Old 04-22-2009, 09:49 PM   #3
FJRFencer's Avatar
That might work, if it HAD a reverse
Old 04-22-2009, 09:55 PM   #4
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
In my first career as a mechanic I found that the very very best lubricant to break stuck bolts etc was old burnt transmission fluid.
willworkforbeer is offline
Old 04-22-2009, 11:37 PM   #5
Inner10's Avatar
Trade: Control Systems
I've used ATF quite a few times, on cars it helps to sock the airhammer to stubborn bolts but I think that was more to break-up the rust. I'm shocked the torch didn't do the trick thats pretty well my 'go-to' method for removing stuck things.
Inner10 is online now
Old 04-23-2009, 12:36 PM   #6
rustyjames's Avatar
Sometimes a couple good shots with a hammer (and a steel dowel if you can't get to it) while you have tension on it will work to bust it loose. Worst case scenario would be to cut the bit off; that could probably done with an oxy-ace. setup or grinder.
rustyjames is online now
Old 04-23-2009, 01:57 PM   #7
jcalvin's Avatar
I had tried everything to get an old trailer hitch off my truck once, pb blaster, wd 40, tranny fluid. Nothing worked. A friend put me onto Kroil. NOTHING works as good as this.
Cal
You hired WHO
jcalvin is offline
Old 04-23-2009, 03:56 PM   #8
rustyjames's Avatar
I think the problem here is extreme tightness and no amount of penetrating liquids are going to get it to break loose.
Old 04-23-2009, 09:30 PM   #9
FJRFencer's Avatar
I cant cut it off, If I do, I would loose a $300 bit and have to re-build the drill with a new drive shaft
Got a link for this kroil stuff? never heard of it.
looks like a gun lube
Old 04-23-2009, 09:31 PM   #10
Dufus Extrodinaire
BHR's Avatar
Something like this http://www.canadiantire.ca/AST/brows...g%2BPliers.jsp
Lock it on and tape it so it wont open then hit her with the hammer
If I had one I would share it
BHR is offline
Old 04-24-2009, 10:38 AM   #11
rustyjames's Avatar
Yes, it would destroy the bit, that's why I said worst-case-scenario. Someone who is good with a torch can cut that off without hurting the drive, it's done all the time to remove frozen bearings/bushings.
